By traceylawson5 - 6 Years Ago
Hi all,
I can't use any existing projects where I need to remove object animation. This seems to have occurred after the latest update. I am running 4.21.1908.1
If I select the object, and right click and choose "Remove Object Animation" it crashes.
If I try a roundabout way by going into composer where is pop up the dialog "Detected new motion in character" (which removes the animation) then I can click on continue, and edit away (or even do nothing at all), then click back to "Back Stage" and it hangs exactly the same way.
I get the busy spinning mouse icon for ~30 seconds and then it crashes out.
I always get the app hung with messages that are slight variations on this:
The Instruction at 0c00007FF670195331 referenced memory at 0XFFFFFFFFFFFFFFC0. The memory could not be read.
Click on OK to terminate the program.
I have tried this on several different project files, all with the same result. Rebooted, checked for updates (none)...I have even done extensive memory testing (just in case)... This is seriously killing my productivity!
Any thoughts? Cheers
To add to this - I found that if I remove the animation elements one by one on the edit timeline, it doesn't crash.
I can then work with the character again (a customized version of Ted's Dog) - icluding going into composer and returning to back stage without hanging.
So I have found a work-around for this character, but it is a little frustrating...
It didn't seem to happen with other characters I have customized, only this one that is in many existing projects (and they all fail) so I am guessing something odd has occurred with that character and the version update as I didn't have this issue before.
