ADD BLENDSHAPES INTO EDIT FACIAL?
https://forum.reallusion.com/Topic455308.aspx
Print Topic | Close Window
By Angel Alonso - 6 Years Ago
Hi, ...Is there a way to add Blendshapes into the edit facial? ...
Or am I wrong about this?https://forum.reallusion.com/uploads/images/5b33ad04-3cd5-4ba4-bd7a-997e.jpg
By Rampa - 6 Years Ago
In the 3DXchange Expression Editor you can add "custom" morphs and they will show up there.
https://manual.reallusion.com/3DXchange_7/ENU/Default.htm#3DXchange_7/Pipeline_7.0/04_Modify_Page/Face_Setup_Section/Introduction_of_Expression_Editor.htm
Sorry....
In the 3dxchange?
but this cannot be done within CC3 ?.
This is the generic model of CC3!
By Eric C (RL) - 6 Years Ago
Hi @ATOOM,
There is no blend shape function in CC.
To custom/modify character's facial base mesh, 3DXchange is the tool for you. Thanks!
https://forum.reallusion.com/uploads/images/6cf54da2-6395-43af-9669-9816.png
By Procrastinator - 6 Years Ago
the edit facial panel is for importing morphs via 3dxchange.
You could try "export iavatar" as  morphs from cc3. And use that iavatar in morph creator in iclone.
