By shoppersplace5 - 6 Years Ago
I am trying out the presentation software. To start off, we have a man pushing the title onto the screen. First, you have manually pan the camera until the title is mostly off the screen to the left. The problem is, the motion of pushing the title into full view is painfully long. I wish to speed up the motion. How would I do that? Its not like just moving one object into full view later in the line. They are all connected. I just want to speed up the whole thing, and then go back to normal speed for the rest of the clip. Thank you. This should be a good one.
By Peter (RL) - 6 Years Ago
Hi...
You can speed up motion clips by making them shorter. So for example if you have a motion clip that 300 frames then it will take 10 seconds to complete. However, if you go into the Timeline, switch to Speed mode by pressing ALT+S, you can then click and drag the end of the motion clip to shorten it to the desired length. So if you shorten it 150 frames it will now only take 5 seconds to complete instead of 10 seconds.
