By zdzislavhendly - 6 Years Ago
Hi.
Im learning on action as much as i can about quick generating a character and im stacjonarny about put photogrammetry Head by wrap to cc3. Time is limited on The trwała so i need help.
When im importing the ready model to 3dxchanger from iclone its look like trash on the image i attached. What is the problem? Can someone help me?
I attaching image and obj to this post. link
By Peter (RL) - 6 Years Ago
Hi...
The OBJ is in a format that 3DXchange and iClone can't open correctly.
Try opening the OBJ in some some other 3D software like the FREE Paint3D that comes with Windows 10 and then export it as FBX. You should then be able to open it in 3DXchange 7.
However, please be aware that the OBJ is just the mesh. Even when you open it in 3DXchange you won't be able to convert it to a character until the model is rigged. As it is it will just be treated as a static prop.
By animagic - 6 Years Ago
I opened the model in Hexagon and saved it out again as a new obj file. See attached ZIP.
This will now import into 3DXchange. The model is not rigged, so it will just be prop. To rig it, you will external software. This outside my expertise, unfortunately.
