Skin darkness
https://forum.reallusion.com/Topic453897.aspx
Print Topic | Close Window
By VRTeacher - 6 Years Ago
I create a character in CC3+ through headshot and send it to iClone.
Somehow the character's face in iClone has darker skin than the same character in CC (under the same light condition).
Is this normal?
How do I maintain the CC skin tone (that I've set) over on iClone?
By animagic - 6 Years Ago
I did a test with the Caleb character included in CC. Initially I also had the character appearing much darker, but then I found there were additional lights attached to two props in CC. There were also a series of effects that influence the render, which I removed.
I recreated the CC scene in iClone, including the position of the character and all light sources from CC and I then rendered at 4k with 3x3 Super-sampling. I think the result is pretty close (iClone renders a bit darker).
https://forum.reallusion.com/uploads/images/7407649a-adc6-4f0a-80c5-f1a5.jpg
By Data Juggler - 6 Years Ago
Lights make all the difference.
Here is Character Creator Mic StandUp: Calechttps://forum.reallusion.com/uploads/images/e2effb44-2b49-4376-aea1-a2de.jpg
Here is IClone without a point light on each side of his face:
He looks like he is either real tired, or just had several bong hits and a shot of whiskey:
https://forum.reallusion.com/uploads/images/538d7317-c2c4-4cbb-b6ea-1f59.png
Some light tutorial I watched on YouTube talked about putting point lights on each side of the face like this:
https://forum.reallusion.com/uploads/images/fd14f4fd-b845-4198-95d6-7641.png
And it sobers him up. That would be cool if there was a sober button for driving:
https://forum.reallusion.com/uploads/images/54cb9ef3-ab3e-41b4-90b0-81ca.png
Makes a big difference, but sometimes I want low light and the same look.
[quote]Data Juggler (8/9/2020)
I don't think that's true.
The skin tone of the first picture (CC without any point light) looks even lighter/brighter than that of your iClone picture (with two point lights).
I believe that the skin tone of the same character should be maintained across CC and iClone when the same lighting is applied.
For example, when you add only ambient light in both CC and iClone, you're supposed to get the same skin tone. But clearly that's not the case. And I don't understand the discrepancy. When you design the skin tone of a character in CC you should be able to predict the skin tone in iClone, but you are not, which I think amounts to a serious bug.
You could sum it up as Character Creator is a campaign promise, and IClone is the actual results.
So you agree that the skin tone is problematic.
How come I don't see any post pointing out this problem?
I couldn't have been the first to notice the problem.
I notice some difference, but CC 3 characters look so much better today than they did a couple of years ago when I first bought this, so I am happy things are going in the right direction.
By wires - 6 Years Ago
Below is the "SkinGen_Skin" Project from CC 3.3:
https://forum.reallusion.com/uploads/images/0badace1-4cc0-4994-8e78-5fde.png
The same Project in iClone 7.8:
https://forum.reallusion.com/uploads/images/da4dbe77-e247-4ba6-8073-3499.png
You can get the same results between the 2, but it won't always be desirable to have the same lighting conditions in an animated scene that is used in a static character scene.
VRTeacher (8/9/2020)
As I clearly demonstrated above, you can get the same results in iClone. Gerry shows that as well.
So why do you ignore these posts and continue to state your non-issue?
What's in it for me if I state my "non-issue"?
I may be ignorant (since I'm new and all), but I don't remember ignoring anything.
I don't quite agree that you "clearly demonstrated above" that you can get the same results in iClone. You yourself said "iClone renders a bit darker" even under the same lighting condition, didn't you?
Now, I just saw Gerry's post. That's fantastic if that means you get exactly the same skin tone under exactly the same lighting condition across CC and iClone. But the other three (you, Data Juggler, and I) failed to achieve that. So I honestly don't understand how Gerry was able to make that happen, but not the other three.
When you set up the same lighting condition in iClone, I don't know how to exactly locate each and every light in exactly the same location and at exactly the same angle (like Gerry apparently did), so I removed all the existing lights from CC and iClone. In CC, somehow you can still see the character even after removing all the lights. But in iClone, the character is solid black so you can't see any thing except its outline. And when you turn on only auxiliary light, the iClone character is clearly darker than the CC character.
So I'm guessing the brighter tone in CC is due to the fact that there's still some light in CC even when you turned off all the lights. Am I wrong about this?
By 4u2ges - 6 Years Ago
Gerry shared a neat trick in the other thread. You save a CC project. You then rename the project extension from .CCProject to .iProject and open it in iClone.
iClone is no different a bit from CC, when it comes to rendering/displaying texture. It is all about lighting and environment.
I can make him look lighter or darker as I will in iClone.
4u2ges (8/10/2020)
Thanks for the tip. I'll try that.
Then, how come you can still see the character in CC after turning off all the lights? (But you can't see it in iClone after turning off all the lights.)
You change ambient light color in Visual from dark blue to black and the character would turn black.
The character is still there trust me :)
https://forum.reallusion.com/uploads/images/05b7ddb5-f0ad-425a-8ea7-5774.jpg
Shutting lights off in CC
By 0oseven - 6 Years Ago
Maybe the answer is that the lights in default Iclone project are different "colours " to the default in CC3,
Also as far as I can see have both have a default IBL image activated but it is different in IC7 to CC3 so this will add to the differences in appearance / render.
I would think regardless of what you set up in CC3 if Iclone is where you expect to do final render or animation then that's where you need to determine your lighting and the look you want.
I am new to Reallusion  so am no expert . I don't like the default settings and have a saved project without any lighting then add my own from various "light rigs" I have set up and saved and try to follow  fundamental lighting  concepts used in photography.
By patrick.williams064 - 6 Years Ago
While I agree that this can be done by adjusting the lighting, It would be good if this can be done with a slider (or maybe a few sliders). This is currently being done with the makeup module so its not impossible.
