FBX / OBJ Invisible
https://forum.reallusion.com/Topic453344.aspx
Print Topic | Close Window
By sencorpx - 6 Years Ago
I have tried everything I can think of. But this object I am trying to import into CC then into IC is always showing up invisible. What am I missing?
Location of file :
https://dreadnaughtcnv301.com/Dock/wp-content/uploads/2020/08/Top.zip
Thanks in advance.
By Kelleytoons - 6 Years Ago
My guess is the scale is wrong.  Try scaling it up a LOT (like 10000x).  If necessary, bring it into Blender and rescale there first.
By animagic - 6 Years Ago
Kelley is right. If I import the object into 3DXchange it says it is too small. It sets the size to 1275, but i think you need something like 5000. You would have to check with an actual character.
To follow up: I imported the top in CC and had to scale it to 3750 to get about the right size.
I also noticed that the model was rotated, so I had to rotate it 12 degrees around the Y axis to get that right. I then corrected the pivot (click Edit Pivot). The Y value was at 348 degrees so I set that to "0".
After making these changes you should now be able to continue from there.
https://forum.reallusion.com/uploads/images/f9b2dd0c-c35c-46a5-a9d9-3633.jpg
Thanks so much for giving me a hand with this. I really appreciate it.
I gave your pointers a try, but I am still getting this.    It wants to be there and a the right size but its telling me no. What am I missing?
***EDIT**** I discovered the transparency settings were the issue.  Really thank all of you for your help.  I have it sorted now.  Cheers everyone!
https://forum.reallusion.com/uploads/images/ef4aa63a-8631-4a44-8e0e-e039.png
