Iray plug in crippled
https://forum.reallusion.com/Topic452270.aspx
Print Topic | Close Window
By hkhaneveer - 6 Years Ago
With the latest update to CC3, I get notices on launch that my Iray Plugin doesn't work and needs to be updated. I don't think I care much because I have no plans to render anything in CC3 anyway, but the messages are annoying. How can I make them stop?
By Rampa - 6 Years Ago
Upgrade your iRay plugin will take care of that. ;)
I never purchased the Iray plug in, and I don't need it because I'm rendering in Blender. So what's the procedure?
By LookingGlassGraphics - 6 Years Ago
@Rampa how are you? I am currently having trouble with the Iray plugin after the new update. I remember you had a troubleshooting technique for the registry. What was it again? I l;iterally had an issue with the CCBasics plugin and had to re-download everything from CC2,CC3,CC3 Pipeline (and now the update) in that order just to get things working again. Only thing is now after all that, the Iray Plugin is failing. I have a few posts going in the Official Character Creator 3.3 Issues Thread if you don't mind taking a look. There's someone else in there with the very same issue I had at 1st. Thanks in advance.
LookingGlassGraphics (7/29/2020)
Iray was updated as well. So please go ahead and update it from the Hub, or reinstall it completely. Current version is 1.4.
https://forum.reallusion.com/uploads/images/6e733e56-d919-47ac-b3d6-280b.jpghttps://forum.reallusion.com/uploads/images/70eee4e1-25aa-48b5-9507-de48.jpghttps://forum.reallusion.com/uploads/images/1e3b07b2-40af-4a55-ad44-437f.jpg
make sure to quit both iClone and CC before installing iRay.
