How do you create a script file that uses manual mocap data to move the hand or a finger?
https://forum.reallusion.com/Topic451645.aspx
Print Topic | Close Window
By delebash - 6 Years Ago
I have tried this script https://wiki.reallusion.com/IC_Python_API:RLPy_RIHandDevice
I also looked at https://github.com/reallusion/iClone/tree/master/HandGesturesPuppeteering for further information but I still cannot seem to get manual mocap data to move a finger on the hand or any part of the hand so I can see how to use mocap data.
Here is my current code that is not working.  Any help or working example would be greatly appreciated!
import ptvsd
ptvsd.enable_attach(address=("localhost"5678), redirect_output=True)
ptvsd.wait_for_attach()
import RLPy
hips = ["hips""""Hips"]
right_up_leg = ["rightupleg""hips""RightUpLeg"]
right_leg = ["rightleg""rightupleg""RightLeg"]
right_foot = ["rightfoot""rightleg""RightFoot"]
left_up_leg = ["leftupleg""hips""LeftUpLeg"]
left_leg = ["leftleg""leftupleg""LeftLeg"]
left_foot = ["leftfoot""leftleg""LeftFoot"]
spine = ["spine""hips""Spine"]
spine_1 = ["spine1""spine""Spine3"]
spine_2 = ["spine2""spine1""Spine6"]
spine_3 = ["spine3""spine2""Spine9"]
neck = ["neck""spine3""Neck"]
head = ["head""neck""Head"]
right_shoulder = ["rightshoulder""spine3""RightShoulder"]
right_arm = ["rightarm""rightshoulder""RightArm"]
right_forearm = ["rightforearm""rightarm""RightForeArm"]
right_hand = ["righthand""rightforearm""RightHand"]
right_hand_thumb_1 = ["righthandthumb1""righthand""RightHandThumb1"]
right_hand_thumb_2 = ["righthandthumb2""righthandthumb1""RightHandThumb2"]
right_hand_thumb_3 = ["righthandthumb3""righthandthumb2""RightHandThumb3"]
right_in_hand_index = ["rightinhandindex""righthand""RightInHandIndex"]
right_hand_index_1 = ["righthandindex1""rightinhandindex""RightHandIndex1"]
right_hand_index_2 = ["righthandindex2""righthandindex1""RightHandIndex2"]
right_hand_index_3 = ["righthandindex3""righthandindex2""RightHandIndex3"]
right_in_hand_middle = ["rightinhandmiddle""righthand""RightInHandMiddle"]
right_hand_middle_1 = ["righthandmiddle1""rightinhandmiddle""RightHandMiddle1"]
right_hand_middle_2 = ["righthandmiddle2""righthandmiddle1""RightHandMiddle2"]
right_hand_middle_3 = ["righthandmiddle3""righthandmiddle2""RightHandMiddle3"]
right_in_hand_ring = ["rightinhandring""righthand""RightInHandRing"]
right_hand_ring_1 = ["righthandring1""rightinhandring""RightHandRing1"]
right_hand_ring_2 = ["righthandring2""righthandring1""RightHandRing2"]
right_hand_ring_3 = ["righthandring3""righthandring2""RightHandRing3"]
right_in_hand_pinky = ["rightinhandpinky""righthand""RightInHandPinky"]
right_hand_pinky_1 = ["righthandpinky1""rightinhandpinky""RightHandPinky1"]
right_hand_pinky_2 = ["righthandpinky2""righthandpinky1""RightHandPinky2"]
right_hand_pinky_3 = ["righthandpinky3""righthandpinky2""RightHandPinky3"]
left_shoulder = ["leftshoulder""spine3""LeftShoulder"]
left_arm = ["leftarm""leftshoulder""LeftArm"]
left_forearm = ["leftforearm""leftarm""LeftForeArm"]
left_hand = ["lefthand""leftforearm""LeftHand"]
left_hand_thumb_1 = ["lefthandthumb1""lefthand""LeftHandThumb1"]
left_hand_thumb_2 = ["lefthandthumb2""lefthandthumb1""LeftHandThumb2"]
left_hand_thumb_3 = ["lefthandthumb3""lefthandthumb2""LeftHandThumb3"]
left_in_hand_index = ["leftinhandindex""lefthand""LeftInHandIndex"]
left_hand_index_1 = ["lefthandindex1""leftinhandindex""LeftHandIndex1"]
left_hand_index_2 = ["lefthandindex2""lefthandindex1""LeftHandIndex2"]
left_hand_index_3 = ["lefthandindex3""lefthandindex2""LeftHandIndex3"]
left_in_hand_middle = ["leftinhandmiddle""lefthand""LeftInHandMiddle"]
left_hand_middle_1 = ["lefthandmiddle1""leftinhandmiddle""LeftHandMiddle1"]
left_hand_middle_2 = ["lefthandmiddle2""lefthandmiddle1""LeftHandMiddle2"]
left_hand_middle_3 = ["lefthandmiddle3""lefthandmiddle2""LeftHandMiddle3"]
left_in_hand_ring = ["leftinhandring""lefthand""LeftInHandRing"]
left_hand_ring_1 = ["lefthandring1""leftinhandring""LeftHandRing1"]
left_hand_ring_2 = ["lefthandring2""lefthandring1""LeftHandRing2"]
left_hand_ring_3 = ["lefthandring3""lefthandring2""LeftHandRing3"]
left_hand_pinky = ["leftinhandpinky""lefthand""LeftInHandPinky"]
left_hand_pinky_1 = ["lefthandpinky1""leftinhandpinky""LeftHandPinky1"]
left_hand_pinky_2 = ["lefthandpinky2""lefthandpinky1""LeftHandPinky2"]
left_hand_pinky_3 = ["lefthandpinky3""lefthandpinky2""LeftHandPinky3"]
hik_bone_list = [hips, right_up_leg, right_leg, right_foot, left_up_leg, left_leg, left_foot,
                 spine, spine_1, spine_2, spine_3, neck, head,
                 right_shoulder, right_arm, right_forearm, right_hand,
                 right_hand_thumb_1, right_hand_thumb_2, right_hand_thumb_3,
                 right_in_hand_index, right_hand_index_1, right_hand_index_2, right_hand_index_3,
                 right_in_hand_middle, right_hand_middle_1, right_hand_middle_2, right_hand_middle_3,
                 right_in_hand_ring, right_hand_ring_1, right_hand_ring_2, right_hand_ring_3,
                 right_in_hand_pinky, right_hand_pinky_1, right_hand_pinky_2, right_hand_pinky_3,
                 left_shoulder, left_arm, left_forearm, left_hand,
                 left_hand_thumb_1, left_hand_thumb_2, left_hand_thumb_3,
                 left_in_hand_index, left_hand_index_1, left_hand_index_2, left_hand_index_3,
                 left_in_hand_middle, left_hand_middle_1, left_hand_middle_2, left_hand_middle_3,
                 left_in_hand_ring, left_hand_ring_1, left_hand_ring_2, left_hand_ring_3,
                 left_hand_pinky, left_hand_pinky_1, left_hand_pinky_2, left_hand_pinky_3]
tpose = [
          01050000,       #hips                   [0]
          -111050000,
          -11560000,
          -1180000,
          111050000,
          11560000,
          1180000.0,
          01180000,       #spine                  [7]
          01290000,
          01410000,
          01520000,
          01640000,
          01730000,
          -31600000,      #right_shoulder         [13]
          -171600000,
          -461600000,
          -741600000,     #right_hand             [16]
          -7716130300,    #right_hand_thumb_1     [17]
          -811613000,
          -831613000,
          -781612000,     #right_in_hand_index    [20]
          -831613000,
          -871613000,
          -891613000,
          -781610000,     #right_in_hand_middle   [24]
          -831611000,
          -881611000,
          -901611000,
          -78161, -0000,    #right_in_hand_ring     [28]
          -83161, -0000,
          -86161, -0000,
          -89161, -0000,
          -77161, -1000,    #right_in_hand_pinky    [32]
          -82161, -2000,
          -85161, -2000,
          -87161, -2000,
          31600000,       #left_shoulder          [36]
          171600000,
          461600000,
          741600000,      #left_hand              [39]
          7716130, -300,    #left_hand_thumb_1      [40]
          811613000,
          831613000,
          781612000,
          831613000,
          871613000,
          891613000,
          781610000,
          831611000,
          881611000,
          901611000,
          781610000,
          831610000,
          861610000,
          891610000,
          77161, -1000,
          82161, -2000,
          85161, -2000,
          87161, -2000]     #   [58]
fram1_data=[-0.05106.89, -3.65, -6.91173.25, -1.78, -11.44, -1.88, -0.06, -6.1412.7, -9.170.19, -48.070.0227.03, -11.940.710.52, -48.92, -0.88, -7.01, -2.0316.6311.54, -1.81, -0.156.9520.594.210.11, -48.010.076.32, -4.320.420.84, -47.31, -0.06, -7.021.87, -1.47, -0.116.66, -0.053.420.62, -2.97, -0.0411.32, -0.060.860.14, -0.75, -0.0211.780.011.430.21, -1.24, -0.0511.31, -0.030.33, -1.320.27, -0.1512.08, -0.00.34, -1.330.27, -0.149.010.018.37, -24.143.38, -3.528.02, -0.02, -2.341.0210.14, -14.04, -0.15, -0.07, -27.4830.5918.74, -28.99, -0.1, -0.127.7836.336.57, -27.99, -0.02, -0.0218.56, -1.48, -48.22, -2.70.213.39, -0.056.6524.69, -4.00.00.0, -0.013.017.06, -2.780.00.0, -0.0, -3.830.0, -3.50.552.15, -0.00.00.0, -5.66, -0.11.08, -0.015.012.78, -3.930.00.0, -0.00.012.78, -2.230.00.0, -0.00.012.78, -3.670.560.82, -0.00.00.0, -5.62, -0.090.34, -0.00.014.26, -4.290.00.0, -0.00.014.26, -2.690.00.0, -0.00.014.26, -3.650.58, -0.14, -0.00.00.0, -5.03, -0.02, -0.52, -0.0, -15.013.89, -3.740.00.0, -0.00.013.89, -2.590.00.0, -0.00.013.89, -3.430.51, -1.3, -0.00.00.0, -4.5, -0.02, -1.18, -0.0, -25.010.03, -2.990.00.0, -0.00.010.03, -1.890.00.0, -0.00.010.033.488.090.045.9219.77, -1.9314.080.060.031.13, -12.31, -70.2928.980.110.073.24, -2.941.2228.0, -0.020.264.0810.776.192.70.213.39, -0.0, -52.26, -28.524.00.00.0, -0.0, -2.75, -5.082.780.00.0, -0.0, -5.530.03.50.552.15, -0.00.00.05.66, -0.11.08, -0.0, -15.0, -16.843.930.00.0, -0.00.0, -16.842.230.00.0, -0.00.0, -16.843.670.560.82, -0.00.00.05.62, -0.090.34, -0.00.0, -18.324.290.00.0, -0.00.0, -18.322.690.00.0, -0.00.0, -18.323.650.58, -0.14, -0.00.00.05.03, -0.02, -0.52, -0.015.0, -21.53.740.00.0, -0.00.0, -21.52.590.00.0, -0.00.0, -21.53.430.51, -1.3, -0.00.00.04.5, -0.02, -1.18, -0.025.0, -24.82.990.00.0, -0.00.0, -24.81.890.00.0, -0.00.0, -24.8]
fram2_data=[6.44106.862.11, -6.0144.52, -2.36, -11.52, -1.83, -0.057.039.661.24, -0.07, -48.0, -0.043.28, -11.53, -0.020.81, -47.99, -0.85, -4.792.472.4811.55, -1.860.025.8610.688.650.17, -47.990.056.93, -0.614.33, -0.25, -47.970.22, -3.0822.35, -10.460.0416.650.03.11, -0.772.420.0111.31, -0.030.78, -0.180.61, -0.0211.78, -0.01.31, -0.281.01, -0.0211.31, -0.010.04, -0.330.20.0212.09, -0.040.04, -0.330.2, -0.039.0, -0.081.2, -5.813.62, -3.518.060.02, -3.8, -0.277.17, -14.01, -0.01, -0.01, -0.677.8171.31, -29.00.01, -0.15, -4.460.726.46, -28.00.05, -0.0713.32, -6.34, -14.73, -2.70.213.39, -0.051.6120.16, -4.00.00.0, -0.02.942.53, -2.780.00.0, -0.05.460.0, -3.50.552.15, -0.00.00.0, -5.66, -0.11.08, -0.015.019.35, -3.930.00.0, -0.00.019.35, -2.230.00.0, -0.00.019.35, -3.670.560.82, -0.00.00.0, -5.62, -0.090.34, -0.00.023.71, -4.290.00.0, -0.00.023.71, -2.690.00.0, -0.00.023.71, -3.650.58, -0.14, -0.00.00.0, -5.03, -0.02, -0.52, -0.0, -15.022.43, -3.740.00.0, -0.00.022.43, -2.590.00.0, -0.00.022.43, -3.430.51, -1.3, -0.00.00.0, -4.5, -0.02, -1.18, -0.0, -25.018.58, -2.990.00.0, -0.00.018.58, -1.890.00.0, -0.00.018.583.498.080.032.2610.43, -4.9314.020.020.074.27, -8.99, -74.9329.00.10.04, -2.67, -3.664.1928.010.050.034.623.087.232.70.213.39, -0.0, -52.71, -22.764.00.00.0, -0.0, -3.650.682.780.00.0, -0.0, -2.840.03.50.552.15, -0.00.00.05.66, -0.11.08, -0.0, -15.0, -14.13.930.00.0, -0.00.0, -14.12.230.00.0, -0.00.0, -14.13.670.560.82, -0.00.00.05.62, -0.090.34, -0.00.0, -17.74.290.00.0, -0.00.0, -17.72.690.00.0, -0.00.0, -17.73.650.58, -0.14, -0.00.00.05.03, -0.02, -0.52, -0.015.0, -18.983.740.00.0, -0.00.0, -18.982.590.00.0, -0.00.0, -18.983.430.51, -1.3, -0.00.00.04.5, -0.02, -1.18, -0.025.0, -24.322.990.00.0, -0.00.0, -24.321.890.00.0, -0.00.0, -24.32]
mocap_manager = RLPy.RGlobal.GetMocapManager()
hand_device_ID = "HandDevice"
hand_device = mocap_manager.AddHandDevice(hand_device_ID)
# avatar_list = RLPy.RScene.GetAvatars()
# avatar = avatar_list[0]
selection_list = RLPy.RScene.GetSelectedObjects()
if len(selection_list) > 0:
            for object in selection_list:  # find first avatar
                object_type = object.GetType()
                if object_type == RLPy.EObjectType_Avatar:
                    avatar = object
                    if hand_device is not None:
                        hand_device.AddAvatar(avatar)
                        hand_device.SetProcessDataIndex(avatar, 0)
# hand_device.AddAvatar(avatar)
hand_device.SetEnable(avatar, True)
hand_setting = hand_device.GetHandSetting(avatar)
hand_setting.SetRightHandJoin(RLPy.EHandJoin_Wrist)
hand_setting.SetLeftHandJoin(RLPy.EHandJoin_Wrist)
hand_setting.SetHandJoinType(RLPy.EHandJoinType_UseParentBone)
hand_setting.SetRightHandDataSource(RLPy.EHandDataSource_RightHand)
hand_setting.SetLeftHandDataSource(RLPy.EHandDataSource_RightHand)
hand_setting.SetActivePart(RLPy.EBodyActivePart_Hand_R | RLPy.EBodyActivePart_Finger_R |
RLPy.EBodyActivePart_Hand_L | RLPy.EBodyActivePart_Finger_L)
device_setting = hand_device.GetDeviceSetting()
device_setting.SetMocapCoordinate(RLPy.ECoordinateAxis_Y, RLPy.ECoordinateAxes_Z, RLPy.ECoordinateSystem_RightHand)
device_setting.SetCoordinateOffset(0, [000])
position_setting = device_setting.GetPositionSetting()
rotation_setting = device_setting.GetRotationSetting()
rotation_setting.SetType(RLPy.ERotationType_Euler)
rotation_setting.SetUnit(RLPy.ERotationUnit_Degrees)
rotation_setting.SetEulerOrder(RLPy.EEulerOrder_ZXY)
rotation_setting.SetCoordinateSpace(RLPy.ECoordinateSpace_Local)
position_setting.SetUnit(RLPy.EPositionUnit_Centimeters)
position_setting.SetCoordinateSpace(RLPy.ECoordinateSpace_Local)
hand_device.SetTPoseData(avatar, tpose)
hand_device.Initialize(hik_bone_list)
if hand_device.IsTPoseReady(avatar) == True:
    mocap_manager.Start(RLPy.EMocapState_Record)
fram1_time = 1000
fram2_time = 5000
hand_device.ProcessData(0, fram1_data, fram1_time)
hand_device.ProcessData(0, fram2_data, fram2_time)
mocap_manager.Stop()
By Yukari. - 6 Years Ago
Hi delebash,
Have you solved this problem?
I tried to run your sample code, and I found that SetTPoseData must be called after Initialize.
You can try it. :)
    hand_device.Initialize(hik_bone_list) // First
    hand_device.SetTPoseData(avatar, tpose) // Second
BR
Zong Ye,
Thank you that fixed the problem.  Just a note that your sample documentation needs to be corrected as https://wiki.reallusion.com/IC_Python_API:RLPy_RIHandDevice shows
hand_device.SetTPoseData(t_pose_data) //First
hand_device.Initialize(bone_list) //Second
I have a couple of questions
1) Can you explain the tpose data?
I believe that each row corresponds to a bone but what do the numbers mean 0, 105, 0, 0, 0, 0,  ?  Does this partially correspond to x,y,z coordinates ?
2) Can you explain the what the numbers correspond to in the frame data?
I think for example frame_data = [-0.05, 106.89, -3.65, -6.91, 173.25, -1.78, -11.44, -1.88, -0.06, -6.14, 12.7, -9.17] that
-0.05, 106.89, -3.65, -6.91, 173.25, -1.78 =  hips and
-11.44, -1.88, -0.06, -6.14, 12.7, -9.17 = rightupleg
Is this correct?
Also can you explain what the coordinates for each body part mean?
The data that I have as input will be time_frame, body_part, xyz coordinates  how do I map this to your frame data coordinates?
Thank you very very very much for your help!!!
Dan
Hi delebash,
I really appreciate you asking me, but I also can not find the more description of these data on the Python API wiki.
But I searched for information about t-pose on iCone manual, and found that there are some documents.
I don't know if this information can help you.
BR
Thank you for the help!!
