By Miranda (RL) - 6 Years Ago
In version 3.3, the workflow for ZBrush and Substance Painter is enhanced. With the UDIM layout option, there will be no normal seams issues. Here is the workflow for reference: - Step 1: Send CC3 Base+ Character to ZBrush via GoZ.
- Step 2: Sculpt character in ZBrush, and send the final shape back to CC via GoZ.
- Step 3: Export normal map (A) from ZBrush, and export mesh (B) from CC.
- Step 4: Paint textures in Substance Painter by using (A) & (B), and export all textures you need from Substance Painter.
- Step 5: Import textures to CC.
By vidi - 6 Years Ago
I have not tried yet, but Substance painter has add a new udim support option . do this has an effect Of this workflow too ?
I follow exactly the export and import setting , but in Pinter it is the same as before I can not paint across UV set Can you show how it work ? :doze:
BTW can you also post the VD Multi Map Exporter Setting in ZBrush ?
For me Substance Painter is absolutely unusable. I have no Idea why the workflow here is needed I was in hope I can finally paint acrossing tiles.? I have no Idea why SP is so overrated . Paint on multiple UV set seamless can 3D coad since years in easiest way .
Oookay I got it RL Maybe you make an additional Export Option to remove all the shader domains from face group Body , then we can use the new UDIM Option in Substance painter without a detour in other programs . At the moment , To paint across tile, we need delete the shade domains from Face Group Body. For that we need to jump in another 3D programm to do. But it would nice go the directly way But, I'm happy it works finally and SP is an Option to paint on a CC Character seamless
if enough interest to the workflow how paint across UDIM UV tiles in substance painter , I can make a video. jump in and give a notice :)
Delete double posting
But this is still for interest for me BTW can you also post the VD Multi Map Exporter Setting in ZBrush , , because the multimap function in Zbrush is another story
After I spend a weekend with the new UDIM UV Layout feature, it is great, I had so much fun to work with. It makes so much easier to use zbrush and SubstancePainter for texturing. It just to the right time hehre with the new paint across tiles feature released For me the best CC feature of the whole uptdates lol. Now I can finally more enthusiasm for Substance Painter Thank you ! :cool:
Hi vidi!
Long time no see! It's super great to see you again. Hope you are doing well. I just updated the flow image to prevent confusion. Please use the CC-generated FBX to Substance Painter.
vidi (7/25/2020)
Hi Miranda,Thank you!:)
I have use the new CC+ fbx version, but for every surface it create its own tile set, therfore i have delete the surfaces and get thus all tiles in the uv view to paintable across. the only downside is the generated maps have not more meaningful names. But is the only workflow that worked in this case for me.
By justaviking - 6 Years Ago
vidi (7/25/2020)
That would be wonderful. :)
vidi (7/25/2020) BTW can you also post the VD Multi Map Exporter Setting in ZBrush ?
Hi vidi! It's a bit late. Here you go. :)
By alex.catalyst - 6 Years Ago
It would be great to see the workflow from CC3 to Substance Painter (without ZBrush).
I just can't seem to work it out, or find a tutorial for something that I imagine should be quite simple.
By NevarrBlue - 6 Years Ago
vidi (7/25/2020)
if enough interest to the workflow how paint across UDIM UV tiles in substance painter , I can make a video. jump in and give a notice :) I would love a video on the workflow. Trying to get to painting my own characters using substance painter.
Oh Thank you !!!:) I see this I just today. That are very value information for me.
alex.catalyst (8/1/2020) It would be great to see the workflow from CC3 to Substance Painter (without ZBrush).
Hello,
A more efficient workflow for Substance Painter will be coming up in CC v3.31. Please wait for further announcement from us. :)
By dirtlux - 6 Years Ago
New CC to Substance Painter update? YES PLEASE! I'm new to the software and initial export/imports were pretty messy in Substance.
Seeking a good work flow from CC3 to Substance so I can paint these beautiful characters!
<3<3<3 looking forward to learning more! @dirtlux
dirtlux (8/22/2020) New CC to Substance Painter update? YES PLEASE! I'm new to the software and initial export/imports were pretty messy in Substance.
Hi dirtlux,
Please find this post for more details. :) https://forum.reallusion.com/456462/09-Substance-Painter-Workflow-New-in-CC-v331
Nice ! this is exactly what I want :)
Image #3 - The settings of Multi Map Exporter in ZBrush
When I use this Setting I get a non working NM Has this changed in the meantime, or is this workflow still valid ?
vidi (10/14/2020)
Hi vidi! I'm not sure if I understand you correctly. May you elaborate more details like what you meant by not working? We appreciate that if there are some images or video clips to show the steps and error. Thank you!
By mikahawkins - 6 Years Ago
There was another comment about not being able to paint across UV, I am facing the same difficulty. Any solutions?
I want try what you describe with the Multiexporter from Zbrush in your Post. The Normalmap is colorfull not blue. so not useful. I have exact these setting that you show in the screenshot
By cynsegura - 5 Years Ago
Thank you so much for your post!! You really help me.I was really struggling how to place the maps! Finally I got it! Thanks to your post!
