How do you map csv motion capture to iClone data?
https://forum.reallusion.com/Topic450976.aspx
Print Topic | Close Window
By delebash - 6 Years Ago
For example if you look at api docs https://wiki.reallusion.com/IC_Python_API:RLPy_RIBodyDevice how is the t_pose_data mapped?Example
bone_list = [hips, rightupleg, rightleg]
t_pose_data
= [0.0, 105.85, 0.0, 0, 0, 0, -11.5] do the first 3 numbers correspond to the hips x,y,z position?How about the fram1_data = [-0.05, 106.89, -3.65, -6.91, 173.25, -1.78]?If I have a csv file with data format like below
Body.translateX Body.translateY Body.translateZ Body.rotateX Body.rotateY Body.rotateZ Hips.translateX Hips.translateY Hips.translateZ Hips.rotateX Hips.rotateY Hips.rotateZ
-15.337641 103.876595 7.788717 0 0 0 -15.938843 100.31266 8.859345 -0.310804 -2.850941 104.551296
-15.336495 103.875458 7.831433 0 0 0 -15.934213 100.309464 8.910808 -0.317408 -2.851971 104.591611
-15.337191 103.874374 7.869067 0 0 0 -15.931573 100.306335 8.957129 -0.32407 -2.850415 104.629859
How do I map this?Can you also explain the facial format?
https://wiki.reallusion.com/IC_Python_API:RLPy_RIFacialDeviceHow do I interpret this?
head_data1 = [0.3, 0.4, 0.5]left_eye_data1 = [0.4, 0.5]right_eye_data1 = [0.4, 0.5]bone_data1 = [0.3, 0.4, 0.5, 0.3, 0.4, 0.4, 0.3, 0.4, 0.5, 0.3, 0.4, 0.4]morph_data1 = [0]*60custom_data1 = [0]*24What is the bone_data?What is the morph_data?From what I can find out the face is strictly driven by morphs instead of facial bones, is this correct?I have a file with 486 3D facial keypoints predicted per frame like below. Keypoints(landmarks) is an array of xzy coordinates starting from 1-486. Do I just map a groups of these to a morph?  Example if I define keypoints 1-10 to be the left cheek group  then I can map that to a left cheek morph?
[  {    "faceInViewConfidence": 1,    "frame": 1,    "timestamp": 1594600292956,    "keypoints": [      [        327.48779296875,        226.72177124023438,        -10.546834945678711      ],      [        327.5000915527344,        218.25994873046875,        -28.060033798217773      ]]}]
Thanks!
