By aayquemedalarisa - 6 Years Ago
Hello, I see that the opening of the lips is exaggerated and I want it to be smoother, that the opening of the mouth was smaller. Is it possible? I have CT8 Standard Version
By Peter (RL) - 6 Years Ago
How are you creating your facial animation?
If you are using Auto-Motion to generate the facial animation for you, then you can go into the Auto-Motion settings from the top toolbar (or press A). In the Standard version you only have basic control but you should be able to adjust the strength to reduce overly exaggerated mouth or facial movements.
Thanks Peter, at least Standard version with TTS doesn't reduce exaggerated mouth movements (or perhaps I don't nottice the difference), but yes with record voice
