By kenmatthews - 6 Years Ago
Hello, I realize I am probably making the most basic mistake, however when I press the Face key or Face puppet key they do not appear (they used to...) so I can do adjustments, can anyone point out my error please, I just can't see it... I know I'm asking a lot of questions, and for that I apologise, but I'm working eight hours a day, re-acquainting myself with the software as I animate one of my books into an animated feature film. Also there have been many changes to the software since the last time I was immersed in iClone, and I realise I have a tremendous amount of ground to make up. Thank you all for your forbearance... Best regards. Ken.
By toystorylab - 6 Years Ago
AFIK there is no shortcut to those panels. And be sure your character is selected...
Hello Toystorylab, Thank you for answering, that's exactly my problem. The character is selected and I press the face key in the modify panel (as in attached pic.) and nothing... It has worked fine for weeks, now nothing... Best regards. Ken.
Hm, that's strange... If a computer reboot does not work, I would reinstall iClone. As all your content will remain, that's only a matter of 10 minutes work. It should work again after reinstall...
Further to my problem. When I click the face key, the Iray preview icon, and camera and object switch (top right of monitor) light up. I click the face key button again and they turn off again. Never noticed that before. I switched the whole system off at the wall, waited twenty minutes, switched on again, still the same. I'm baffled...Does anyone have an answer please?
Best regards. Ken.
I've reinstalled iClone 7 twice, closed down the computer and lastly uninstalled iray, I can now get the face puppet by clicking on the button, but not the face key... I'm giving up for the night as I need the face key. Please... please can someone help me?
Best regards. Ken
Did you have a 2 monitor system and then changed to a one monitor system? In some cases the pop-up window could pop up on a not existing monitor, so you can't see it. Sorry, but I have no idea what you could do further... Either Peter (RL) chimes in here or you contact customer service (you find that in your Reallusion account)
Thanks Toystorylab, I've never worked with two monitors, however, is it possible I've hit a control that told the programme I was using two? It's so disappointing, I was making such good progress, now I've got it in my head that the face key is essential... Truthfully, it probably is essential, at least for what I'm doing... Mañana...
Best regards. Ken
By ocapvr - 3 Years Ago
Hi Ken,
I came across exact the same issue in iclone 8 (everything works fine apart from Face Key window not launching). I've tried reboot, reinstallation etc but it still doesn't work. I just raised a ticket in the reallusion support, meanwhile I wonder did you manage to solve the issue?
Thanks, Shu
