By 3DChick - 6 Years Ago
Hi all, I picked up a used iPhone (newer than X but can't remember exactly what right now). The front facing camera has some debris in it, and I'm told that can be fixed, but not sure if I need to shell out for that...it is the front facing camera one uses for the mocap? or can the rear one work?
Thanks for any info!
Nicole
By Kelleytoons - 6 Years Ago
It's the one that does facial ID -- if the phone does facial ID fine you'll be okay (you can also just load the iPhone app on and see how it functions).
Thank you, Kelleytoons. I'll have to play with it and see. :-)
By Eric C (RL) - 6 Years Ago
Hi @nelm2010,
Just make sure the iphone that you are using is equipped with TrueDepth camera. Because our Live Face is only compatible with this technology. You can check the information here on our Live Face webpage
Thank you, Eric! I will double check that!
