Module version incompatible error Motion LIVE and Faceware
Home
iClone 8
Plug-ins
Motion LIVE Profiles
https://forum.reallusion.com/Topic448761.aspx
Print Topic
Close Window
By animagic
6 Years Ago
I usually run the legacy Faceware plugin, which works fine, but I wanted to try the Faceware profile with Motion LIVE after a question on the forum.
When I launch Motion LIVE, I get an error like the following:
I had also the Live Face profile installed, which gave the same error.
I uninstalled everything and downloaded fresh and reinstalled Motion LIVE and the Faceware profile, but I get the same error.
The message is not very helpful as I have no idea what module version they are talking about. It's not a big deal as Faceware is the only Mocap I use at the moment, but that may change.
By AllenLee (RL)
6 Years Ago
Hi animagic,
What versions are your Motion Live and Faceware Profile?
You can update these two plugins to the latest version with Reallusion Hub.
MotionLive Release Notes:
https://mocap.reallusion.com/iclone-motion-live-mocap/release-notes.html
Faceware profile Release Notes:
https://mocap.reallusion.com/iClone-faceware-mocap/
Allen Lee
By animagic
6 Years Ago
Hi Allen,
I did update them both. Both say version 1.02 and according to the Hub that should be the latest.
I tried installing on a second PC and that worked OK, so it may be something in my environment.
EDIT: Allen, I've sent you a PM.
