By sritcp - 6 Years Ago
Newbie question. I added a "Run forward" animation, by applying 1S-2L-3E in that order. The resulting run distance was not adequate, so I added an extra "run" segment: 1S-2L-2L-3E I don't get the desired result; the second 2L component is looping by going back and repeating the same segment, instead of continuing the run from the end point of the previous 2L segment.
Thank you for your help.
the topic should read How to "not loop" instead of "not loo" !!!!! I tried to edit, but I can only edit the body of the post, not the title.
OK, I figured it out! Right click on the first frame of the additional run loop segment and choose "Align to Hip"
