CC2 iClone and the Struggel to get Models from as an sample cinema 4d in to CrazyTalk
https://forum.reallusion.com/Topic447277.aspx
Print Topic | Close Window
By support_20090922190427344 - 6 Years Ago
Programs that i use  : CC2 CC3 iClone7  and CrazyTalk8
Files i wanna import  are  obj or fbx   from Cinema 4D
Dear Folks  I wanna use a simple Cartoon Character from cinema 4D in CrazyTalk to animate it  .  The Cartoon Charakters  are super simple  "TeddyBear" like  thingys  nothing  Hardcore   ....  Do I need  now  §DXechange  for iClone  to get the obj/fbx file imported   >  can I then  export  from  iClone  to CC2  and >> then  into CrazyTalk  ?
Or does  iClone 7 do not work then  with cc2  ergo no chance to get the  File importet  to crazytalk?
Thanks for tips
By animagic - 6 Years Ago
Character Creator only works with Character Creator files as well as specific DAZ or Poser characters that are imported using the Transformer function. You will not be able to import a model from Cinema 4D.
Also, CrazyTalk only supports Character Creator 1 or 2 models. CC3 in not supported.
As CrazyTalk only uses the face, it might be easier to render the face from your character in Cinema 4D and then use that to create a 3D model in CrazyTalk.
