By inash - 6 Years Ago
Anybody have any idea how to import DAZ Teeth or the teeth morphs?
By kungphu - 6 Years Ago
There probably a faster and more efficient way to do this, but if you import a character with transformer, just make sure they have the teeth morph you want. Once the character is in CC, just save the teeth of the character in your custom folder. Now you have that one set of teeth saved. Not sure about importing a teeth only morph or multiples at a time. But at least there is a little work around.
That's the thing. Not sure what I'm doing wrong if anything but the teeth morphs don't import. The teeth come in normal nut the morphs on the body will come in fine.
Ah... so you’re saying you morph everything in Daz (including the teeth and via transformer the teeth come into CC3 without the morphs? I’ll try that here in a sec on my machine and let you k ow if I have the same problem.
Hmmm just used the gap and canine tooth morphs on a Gen 3 Character and they came in just fine to CC? Have you checked to make sure you defiantly have the morphs embedded. As in opening the mouth in Daz to make sure they’re applied in Daz?
