GameBugTV (5/15/2020)
I put in a sound clip into my iClone 7 project and after I was done with it wanted to remove it. Can't find it anywhere in the scene tho and it is still there. I deleted all the props, still there. Nothing is listed under sound. When I mute the music it still plays. How do I delete an invisible sound clip?
How did you add the sound to your project? If you dragged the file into the scene it may have attached itself to one of the props. If that is the case you will have to find the prop and then you will be able to remove the sound.
EDIT: Sorry, it was late and you said you already deleted all the props.
