First time using GOZ got this problem :(
https://forum.reallusion.com/Topic443917.aspx
Print Topic | Close Window
By Giovanny Arce - 6 Years Ago
Hello, this is my first time using GOZ with Character Creator 3 and I'm having this issue. Is this normal? The brush size seems to be too small and can't increase it any more than that.
Also, is that size normal?
I downloaded the CC3 templates for 3DMax and Maya (I'm using Blender) but the FBX I'm importing to  Blender seems to be the correct one. I guess this is a bug between the GOZ Bridge.
I'm the only one having this problem?
Also, do you guys have an official Discord channel? This is essential O.O !
Thx
https://forum.reallusion.com/uploads/images/f84d1d35-7c2f-489e-902d-acfe.png
Here a video I recorded showing the problem when pressing GOZ button.
I also did a screenshot showing the scale relation between iClone Female and the Default Zbrush Star. I modified the GOZ import as a subtool to the current object to get an idea of the scale difference. Is HUGE! I reset everything in Zbrush and nothing...
https://forum.reallusion.com/uploads/images/dd36735e-7172-444a-a8f0-929e.png
I guess I will have to send a support ticket :( :exclamation:
By Slayerazazel - 6 Years Ago
Avatash,
You need to increase your draw size. Go to Preferences Tab > Draw > Change Max Brush Size from 1000 to 5000 > Change Dynamic Brush Scale from 1 to 50.
That should fix your issue.
https://forum.reallusion.com/uploads/images/d3900713-0c41-4b21-a86b-d94c.png
https://forum.reallusion.com/uploads/images/2aabc0b2-2fe1-456a-b974-2901.png
Slayerazazel (5/12/2020)
Avatash,
I've been using Zbrush for almost 10 years and I never knew of this feature :O .... Thx a lot Slayerazazel!
No problem. Glad to help.
