02 CTA 4.3 After Effects Plugin Learning Resources
https://forum.reallusion.com/Topic443511.aspx
Print Topic | Close Window
By Ola(RL) - 6 Years Ago
In this forum thread, you will find related learning resources for CTA 4.3 provided by Reallusion official.
Materials are listed as below and will update whenever we have new content.
  • Tutorial Videos
    • How to export a CTA project into sequence images & Json format for AE
    • How to setup AE and load sequence images & Json files from CTA
  • Sample Projects
    • 2D Ninja Character Animation - Cartoon Animator without AE plugin
    • Touched Up with Special Effects - Cartoon Animator with 4.3 AE plugin
May 7th updates
  • Touched Up with Special Effects - Cartoon Animator with 4.3 AE plugin.
By Hayzie - 6 Years Ago
These videos are no learning resource I'm afraid. They are the end result...not How-To videos. Can we get some instructional videos, please?
Thanks
By KanoEder - 6 Years Ago
Hayzie (5/8/2020)
Thanks
You can follow this video to export the sequence images and json file to the After Effect and through the AE script to import the json.
You will see the CTA objects into the After Effect.
When you exporting the CTA project as sequence images and json, you can refer this video to import the json into the After Effect.
How to setup the CTA launcher of jsx to the AE script:
By guguchao - 6 Years Ago
The new AE plugin can be use from 2020 to CS6 version.
About AE effects, There’s some video help you to build motion blur or camera shake.
Camera moves, this section is bring from CTA that you set before, therefore when you work in AE, there are much detail can modify here, like shake.
