PSD File won't import
https://forum.reallusion.com/Topic443430.aspx
Print Topic | Close Window
By steve_567099 - 6 Years Ago
Someone has created a character for me for some training videos but it won't import into CTA Pipeline.
I'm trying to use it to replace the sprite on the G3 human dummy. I've opened it in photoshop and the layers are there so I'm hoping someone might be able to make a suggestion so I can work out whether the problem is with the character build or a glitch on my MacBook.https://forum.reallusion.com/uploads/images/fb011c7c-0e7c-4aea-9e7a-9b02.png
https://forum.reallusion.com/uploads/images/7ac4bb45-7f21-4683-a4f8-e1ec.png
By Peter (RL) - 6 Years Ago
Hi...
It's not just a case of having a character in layers, you also need the correct grouping structure for the character to import correctly as a G3 character.
The best way to learn the process is to first load a G3 Template and then just replace the sprites with your own sprites as explained in the video below.
https://youtu.be/AIQ8ArWQiYc
Brilliant, thanks Peter
