Voice changing Software
https://forum.reallusion.com/Topic442796.aspx
Print Topic | Close Window
By Bushy2490 - 6 Years Ago
I can anyone suggest any voice changing software that will work with Cartoon Animator 4 and Crazy Talk? I was hoping to try my hand with a view to maybe using it to tutorial some software we use at work - any advice would be greatly appreciated before I commit to purchase.
Thanks,
J
By wendyluvscatz - 6 Years Ago
I use Morphvox Screaming Bee
it also can morph existing files and TTS as well as playing live as you chat on Skype etc
https://screamingbee.com/morphvox-voice-changer
By kmitchell.12catblackstudios - 6 Years Ago
My results using MorphVox:
Before:
https://www.youtube.com/watch?v=w8ageBe6oSs
Not sure how to get rid of the distortion. If i can get it clean I would consider it.
After:
https://www.youtube.com/watch?v=pTmpt6e2pKA
Thanks - will this also work with IClone 7?
I am only on iC6 but I never record within the app, I always load an mp3 or wav file under script, even with TTS as you can edit and clean up the recording in Audacity or other software first. I have never found the record quality of iClone at least up to 6 to be as good as loading a wav file recorded by other means.
By jlittle - 6 Years Ago
You can usually get rid of most of the artifacts by running the audio thru an EQ with the high end reduced.
Jeff
By 3dtester - 6 Years Ago
Besides MorphVox, there is also a program called 'Voxal' (https://www.nchsoftware.com/voicechanger/index.html)
I used it for a few projects and got some nice results. Even though it's gui was a bit confusing at first, i really like it.
You can load or record wave files and also use it in realtime, as it injects itself into your standard mic input.
As a side note: i initally used a basic headset microphone, but now with a seperate semi-pro mic it works much better (no wonder).
