By paulomara - 6 Years Ago
Hi I hope every ones well?
Complete newbie, waded in got characters, scene, animations all sorted. I can export 1 view .mp4 etc Here's the million dollar question:
Can I export the full 'movie' from iclone? from the perspective of an animated camera or do I have to export it all to some other programme to render?
Any help very gratefully received!
Thank You
By Peter (RL) - 6 Years Ago
Hi...
You can add multiple cameras to your project and switch between them as required. Please take a look at the tutorials below. These are a good introduction to using cameras in iClone.
https://www.youtube.com/watch?v=Za2HODK2ACk
https://www.youtube.com/watch?v=LOFDJLz0jPM
Thank You Peter. When I am happy with everything, how do I export everything from the viewpoint of the cameras? Is that done through iClone or do I need to export to an external programme to render? That is what is confusing me
Thank You Paul
By Clark - 6 Years Ago
Paul On the timeline use the switcher line to select the camera that you want to be active at that point. Then when you select switch as your camera it will select the appropriate camera at the selected location when you view or render your project.
Clark
Ok so I can set up a revolving camera ( for example ) switch to that & that is the view that will get exported? I will give that a try
Thanks
Paul
