By toystorylab - 6 Years Ago
Rosuckmedia from German Forum asked to post this https://forum.reallusion.com/440796/Iclone-7-Tur-auf-und-T%C3%BCr-zu- here in english...
Hello everyone, Does anyone know a solution for this? I have set keyframes for door open and door closed, door open at a 45 degree angle then added to "perform" via collect clip. Door open works perfectly, but when the door is closed, the door always goes the oppsite way, even though the last keyframe for Z axis rotation is at zero In Iclone 6 this worked wonderfully, but not in Iclone 7. I tried everything in Iclone 7 but found no solution... Greetings Robert
 I tried it myself with the same result. Then I tried it with a reverse motion to perform but that did not work either. Do we "think" wrong or is this a bug?? Thanx for helping!
By 4u2ges - 6 Years Ago
I do not think consecutive perform actions has ever worked (tried in IC6 - does not work). Suppose it only records a delta value (rotate Z 60 degrees for instance). But it starts from the initial angle value which is 0 in this case. Unless there is some trick to make it working, workaround is to record whole action Open/Close. Then, when you run it from Perform, break the clip in half and have second (Close) clip where you want it.
By rosuckmedia - 6 Years Ago
@toystorylab Thank you for posting this to me. @4u2ges Thank you for the answer, I was of the opinion that it worked in Iclone 6, sorry I was wrong, Will try this with clip Break, thanks again. With best regards rosuckmedia:)
Hallo In Iclone 6 there was the possibility to open and close the door at a 45 degree angle with the help of a door dummy. The idea does not come from me but from Cyberopa, I would not have thought of it. However, this variant no longer works in Iclone 7. I made a little tutorial. Greetings Robert
Hey Robert, Very interesting. Thanks for sharing. I think the problem with iClone7 is, that it does not save animation while Props are merged. Not sure if RL did it on purpose or it is just a bug.
I however used a native iClone7 tool - morphs to record open/close perform action:
@4u2ges Great idea Thanks for the Tutorial.:) Best regards Robert
By Data Juggler - 6 Years Ago
Yes props attached to a parent seem to have weird behavior. I found it works better to remove a prop from the parent, but some of the transforms change when added back to a parent, so Python is probably the right way to do some of this instead of Perform menu.
I have never used Morphs, thanks for the video. I will make this my 'What I learned this weekend'.
P.S. I am going to buy you a microphone and / or a narrator for Christmas so you can explain what you are doing in your videos.
lol thanks. I have a mike, but I only made one tut where I speak. I hate my accent and voice for that matter. :Whistling:
By StyleMarshal - 6 Years Ago
@4u2ges , haha , I can absolutely understand you , right now I have to do a voice over Tut and I hate to do it ;-)
Oh yeah, I could do one of those TTS voices, but it takes time and I hate those voices even more than mine :D
By bernierao - 6 Years Ago
You can try using speechelo for your tut - https://speechelo.com/ - they have voices that sound pretty good these days!
Thanks. Quite impressive. Fairly inexpensive and no monthly commitment. The only drawback is, that it's an online product and there is a chance it could be consumed by one of common sharks like Google or Adobe. Then we know what's going to happen...
By thebiz.movies - 6 Years Ago
Using morphs is a pretty clever alternative. I like!
thebiz.movies (8/22/2020) Using morphs is a pretty clever alternative. I like!
Thanks.
I followed an advise from bernierao. Here is a narrated version:
