CC3 Characters all have their shoulders too high and thumbs contorted when exported to Unity.
https://forum.reallusion.com/Topic440303.aspx
Print Topic | Close Window
By Drenyn - 5 Years Ago
I purchased Character Creator 3 about a year ago and would love to be able to utilize it in my games, but unfortunately I've not been able to get the kinks worked out.   I'm assuming the issue is how the Character Creator 3 is rigged as I've noticed to can fix some of these issues by altering animations, even though using other characters from Unity Asset store have no issues with the rigging on these same animations.  My biggest issue currently is that my character's shoulders are too high and going in and adjusting the muscle doesn't lower them down enough to look normal.   Also the thumbs appear contorted.   I've found I can go in and edit animations to correct this, but I hate to go in and edit every single animation that I've purchased from the Unity Asset store to correct this issue when other characters from the Unity Asset store, etc... don't have the same issue.  I highlighted the problem below.
https://forum.reallusion.com/uploads/images/753a8795-7b46-40a2-9e26-f236.png
Can anyone please help explain what might be causing the issue?   Would this be an issue if I were using Reallusion animations?   I'd really like to purchase some, but don't want to find out the hard way and then be out additional money for Iclone and the 3dexchange.
Thanks for any help you can provide.
By Miranda (RL) - 5 Years Ago
Hi Drenyn,
We did a test, and it's likely to be the same issue as this one.
Though we were unable to reproduce the shoulder issue, thumbs and elbows indeed were twisted after importing into Unity.
The possible reason is that CC character skin is bound to bones, which benefits are not applicable on Unity.
We will check how we can fix this part.
By pelix_987971 - 5 Years Ago
Hi Miranda,
I have this issue as well, the shoulder is way too high, i do feel the clavicle bone is a bit too short.
But wondering if there's any update on this issue ?
Thanks
By BazMitch - 5 Years Ago
I also have this issue with all CC 3 characters. Please help!
By arudz - 4 Years Ago
Bump for sure, dealing with this hard core
https://forum.reallusion.com/uploads/images/1d5e2714-94d5-4882-b34f-ce87.png
I ended up just working around by bringing the shoulders all the way down.
I was inputting Rokoko mocap and was getting this error, seems better nowhttps://forum.reallusion.com/uploads/images/7face5ba-d199-4b1e-90e9-7c60.png
By Drenyn - 4 Years Ago
The best fix that I found for this issue was to just use the Reallusion Animations.   Sadly the issue is actually related to how the character is rigged, so when trying to apply other animations to a different rig, you get the result pictured above.  I've tried doing other work arounds by lowering the shoulders and such, but the best solution was just using ActorCore animations or Mixamo and having them match the CC3 rig as is explained in the CC3 tutorial video about Mixamo and Unity.
