By deidrereaystudios - 6 Years Ago
So inside cc3 you can edit the facial expressions of your character, but then when exporting into iclone 7 there are all gone.. Is there a workflow for this? Am I missing a step? Is there a way inside of Iclone 7 to set facial expressions (I dont want to use the mocap which we have thats meant for video i would assume and just trying to get a still image of several characters but they need expressions on those life less faces) Thank you in advance for the help.
By Peter (RL) - 6 Years Ago
Hi...
iClone 7 has the same facial expression editor as Character Creator 3. With a character selected in iClone 7 go to the Animation tab of the Modify Panel and then choose "Face Key" to access it. You can also use "Face Puppet" when you want to create facial animation for your characters without using mocap.
You can find more information about creating facial animation below.
https://manual.reallusion.com/iClone_7/ENU/Content/iClone_7/Pro_7.4/00_LandingPages/Real_Time_Facial_Standard.htm
Thank you for the quick response
