Is There A Way To Use Parts Of An Animated Motion?
https://forum.reallusion.com/Topic439044.aspx
Print Topic | Close Window
By NaturalGlitch - 4 Years Ago
I have a scene with four people sitting in office chairs around a table. I was wondering if there was a way to use the top half of the motions? Like, is there a way to keep them sitting and perform the animations?
I know I probably should use this opportunity to try to self-animated the scene, but while attempting that, this thought occurred to me.
By toystorylab - 4 Years Ago
You can (could) do that with "masking" in "Motion Puppet (under "Animation")...
Haven't used it for a while, but it seems broken.
With or without masking, using motion puppet made iClone crash immediately Pinch
By vepop - 4 Years Ago
You can actually remove motion for the other sprites.
Oops, didn't see you were talking about Cartoon Animator Blush
I was talking about iClone...
Well, at least now I found out the function is broken Wink
vepop (3/27/2020)
I had no idea this was a thing! Wow—thanks!
I go to Remove Animation, but I don't get a drop-down menu; do I need to update CA4?
Edit: Oh~ You have to right-click the Motion in the Timeline itself~ Sorry; I didn't know that.
toystorylab (3/27/2020)
Don't worry; that's fine. I should've added CA4 in the tags. I'm always happy for posts, regardless!
Refer here:-
https://manual.reallusion.com/Cartoon_Animator_4/ENU/Pipeline/Content/Resources/ENU/09_Timeline/Removing_Motions_of_Body_Parts.htm?Highlight=remove%20animation
