Headshot missing
https://forum.reallusion.com/Topic438902.aspx
Print Topic | Close Window
By stfgamedev - 6 Years Ago
Headshot was installed but there is no plugin label or icon for it in CC, is there any chance to make it work?
https://forum.reallusion.com/uploads/images/3113bfbe-b994-4067-b245-06dc.jpg
https://forum.reallusion.com/uploads/images/294bd51f-3056-4eab-ad6d-af6b.jpg
By Peter (RL) - 6 Years Ago
Hi...
Did you install the Headshot plug-in while Character Creator 3 was open? If so that could have caused the problem.
The first thing to do is to try restarting your computer and then open up Character Creator 3 and check again. This seems to work for some who have problems with plug-ins not showing up.
If Headshot is still not available, please try uninstalling it from Start > Settings > Apps and then reinstall ensuring that Character Creator 3 is closed down during installation.
I took both steps, but unfortunately the effect is still the same. Cant find Headshot plugin in plugins tab or anywhere else
Thanks for updating us.
Although a bit of a pain it might be wise to try uninstalling the Headshot plug-in and also Character Creator 3 and do a fresh install of both. This will eliminate an issue with your original installation. Uninstalling will not remove any installed content packs so the process shouldn't take too long.
Full reinstallation worked. The plugin appeared in the expected location. Thanks a lot!
