Freebie Character - Sandra
https://forum.reallusion.com/Topic438661.aspx
Print Topic | Close Window
By Figment - 6 Years Ago
Hi, I recently downloaded the freebie character offering - Sandra.
It loads fine, accepts motions as it should but the problem I'm having is when I try and take the character into the Composer stage.
If it is just the character it opens in Composer just fine.
IF however, I add even a single motion to the character it will NOT OPEN in Composer.  In FACT IT HANGS my program.
The only way out is to use Task Manager and END Task.
Anyone else have this issue?
I've checked and I have the latest Version of CA4.
By Peter (RL) - 6 Years Ago
Hi...
Sorry to hear you are having problems with the new freebie Sandra character.
I have tried with a few different motions and don't have any problems going into Composer mode.
Can you let us know the name of the motion(s) that cause the problem for you in case the issue is only related to certain motions. Thanks.
