Wet look character?
https://forum.reallusion.com/Topic436566.aspx
Print Topic | Close Window
By marcneuffer - 6 Years Ago
I have a scene with an avatar coming out of the water. Does anyone know how to make it look wet?
By Lamias - 6 Years Ago
I would mainly play with the "Roughness" map. If you lower the brightness and tinker a bit you can achieve a pretty good result.
https://forum.reallusion.com/uploads/images/8664f448-a344-42df-88e0-7776.jpg
Of course, using the right lighting plays a major role. So, after lowering the "Roughness" map, load some spotlights and move them around your character to achieve a better result.
OH! Than you SO much!
By pinguintje - 6 Years Ago
And this is with PopcornFX - Flick Water.
https://forum.reallusion.com/uploads/images/822ae4ef-0d34-43c6-ae89-c0e4.jpg
Best Regards,
Arie
By Kelleytoons - 6 Years Ago
Don't forget that clothing and hair need to also participate to "sell" the concept.
https://forum.reallusion.com/uploads/images/6ace02b0-3fed-4f99-a83f-5dd0.png
By Leowald - 6 Years Ago
Hello!
These tips works great for a picture, but what about an animation?
I need to animate a character who is not yet wet but who finds himself soaked a few seconds later. Is there a solution?
Or do you necessarily have to create two characters: a dry one, and a wet one and play the transition to video editing ...?
If there is a tip I am interested.
Thank you in advance.
Nearly any map can be animated, so you could make animated maps that show your character getting wet.
How can I do this?
I just would like to be able to change the roughness/brighness like the exemple here but in the timeline for animation.
As I said, create an animated map and drop it into that roughness slot (use any photo editor -- heck, you could even use iClone itself).
I'm not sure to understand, sorry in advance if what I'm doing is stupid :pinch:
I made a .gif of my texture to allow me to be dry or wet and drop it into the slot as you said.
I get like a play button on the icon now, but I don't see any parameters to be able to change in the timeline. :(https://forum.reallusion.com/uploads/images/81f1a7e2-8f9c-445a-93b7-9e3d.jpg
You can't adjust a clip on the timeline -- it will be whatever it will be.  You need to make the clip to work exactly the length and speed you want.
Oh ok I understand.
Thank you for your help, I'll try to animate what I need to the right moment then :D
By 4u2ges - 6 Years Ago
https://forum.reallusion.com/FindPost356200.aspx
Thanks for the link! It's easier to use for animation!! :w00t:
