Iclone Render
https://forum.reallusion.com/Topic436523.aspx
Print Topic | Close Window
By Chase MT - 6 Years Ago
Hair Render
Hi.  I'm rendering this straight through Iclone native at 1080p.  The only think checked is "Final Render".  Everything else is unchecked.  This happens with the same character at different scenes as well. Any ideas?
My PC CPU is Ryzen 9 3900x with Geforce RTX 2070 Super video card.
Thanks.
By animagic - 6 Years Ago
I had something similar and reported it in FT.
https://www.reallusion.com/FeedBackTracker/Issue/Artifacts-when-rendering-hair-close-up
Molly (RL) provided a solution:
Please download ROV Tool, double-click IC7-CC3-Rov-ON-2.reg and try it again.
Please let me know the result.Thank you very much.
Molly
Reallusion
That fixed it!  Thank you so much!
By Stintfang - 6 Years Ago
had this problem too. the ROV tooltip managed to fix it for me too. sometimes.
I discovered that disabling "Subsampling" in the render-tab helps too. It seems to keep the renderer from trying to use layered textures like in hair structures.
But I wish Reallusion would really rethink this properly because my main character I use relies on a certain hair mesh and I haven't found any marketplace or Reallusion hair that would be able to replace it without crashing her look.
By 4u2ges - 6 Years Ago
Thanks Animagic!
But question to RL:
Why this ROV2 value of 1 goes into iClone registry in the first place and what exactly the benefit of keeping it?
There should be more explanation and ability to turn this ON/OFF inside iClone if necessary.
So many people (including me) are having this problem constantly and the solution was to just delete a registry key? :crazy:
