Animating Police Car Sirens
https://forum.reallusion.com/Topic435972.aspx
Print Topic | Close Window
By plan111 - 6 Years Ago
Hi
Question 1: I'm trying to animate sirens on a police car. I loaded a sphere prop to which I apply a glow to make it blurry. Then I keyframe the opacity to animate the siren flashing, copy the sphere, change its color, move it to the other siren and delay it a bit in the timeline. The glow is not big enough though. It doesn't get blurry enough.
Does anyone know of a better way to do this? I have Popcorn FX, don't know if it helps.
Question 2: Is there a way to merge multiple props into one. Not attach or link, where if you attach let's say 6 props, they're parented to the parented, but there still are 6 props. I  want to merge them into just one prop.
Thanks
By thebiz.movies - 6 Years Ago
plan111 (2/14/2020)
Thanks
There is a merge option on the parent of the subprop in the attach menu.
By Kelleytoons - 6 Years Ago
If you go to Visual/HDR settings you can adjust the bloom scale to get as big a "glow" area as you'd like.
https://forum.reallusion.com/uploads/images/625481b8-4663-4cd8-aa6d-6a3e.jpg
I'll check it out. Thanks.
Cool. Thanks.
By gordryd - 6 Years Ago
Also, if you go into the 'Light' section of the 'Atmosphere' (used to be called 'Stage', I think, to the left of 'Props') section you will find a pre-canned animation of alternating blue/red lights flashing that you can pop into your scene to illuminate it.  I'm at work right now so can't give more specific directions.  Hope that helps
Cool. Thanks.
