CrazyTalk 8 Install Error
https://forum.reallusion.com/Topic435629.aspx
Print Topic | Close Window
By estilosincreibles - 6 Years Ago
Hello everyone!
I have a problem with install CrazyTalk 8 on my MacBook Pro (13-inch, Mid 2012) (MacOs High Sierra 10.13.6)
During the installation process i got this
"Case-sensitive drives does not supported."
I was looking for a solution and internet says that i need another file system on my hard disk Mac OS Extended [Journaled].
But i can not format my disk right now. So the question is, if I can install CrazyTalk 8 on pendrive and how to do that ?
By Peter (RL) - 6 Years Ago
Although a bit of a chore you really you would be better to add a new partition or format your main drive to a HFS+ or HFSJ non-case-sensitive drive. Having a case sensitive drive can cause problems with other software as well as our own so it's worth doing when you get time.
thank you for answer,
but is there any possibility to install it on pendrive or no ?
As I understand it you normally need to install the software first and then move it from the Applications folder over to the external or flash drive. As you can't do that I don't think it will be possible. However as I'm primarily a Windows user a more experienced Mac user may have another solution.
ahhh :( that's a pity :(
