By sg1caprica - 6 Years Ago
I'm using iClone 7.7.35x and Character Creator 3.2.23x. I have a daz character that I brought in through the transformer. Everything looks great in Character Creator, but when I send to iClone, the character's eyes appear crossed (as in both are pointed inward.) I thought it was a daz issue, so I tried it with the default CC 3.2 character and had the same issue. I have tried using the Eyeball Distance morph (in CC) and separating them as far as possible (without poking through the eyelids.) I've also tried having the character look at a prop and tried having her look at the camera but nothing works. Is there a solution for this?
By Kelleytoons - 6 Years Ago
So you're saying that just exporting the default CC3 character into iClone you end up with eyes that don't work? Sounds like something is wrong with your programs and/or content. You might try reinstalling. I've never seen anything like using the default characters not working in iClone.
I think I figured it out. I was replacing the character (instead of sending to iClone with no character selected.) When I replaced my character with the default character, the default character's eyes were indeed crossed. When I de-selected my character and sent the default character, everything was fine. I'm still not sure what I did to make my character's eyes crossed, but it must have been some kind of setting or pose or something like that. Thank you so much for your prompt reply! It helped a lot to know it had to be an issue on my end.
Good for you to get it straightened out, then (and you also then learned something else which a lot of people forget -- you can send a character over to be added or, if the character in iClone is selected, you can send it over to be replaced. Both are important things to do at times).
