How can I change the framerate of the timeline from 30 to 25 fps?
https://forum.reallusion.com/Topic432422.aspx
Print Topic | Close Window
By tim_412268 - 6 Years Ago
Hi
how can I change the framerate of the timeline from 30 to 25 fps? I have other video project in 25 fps and would like to synchronise music with animation and video later on. I found the way to chance the fps of the export, but how about the timeline in cartoon animator?
regards
Tim
By garylearntech - 6 Years Ago
Hi Tim - I've seen it stated officially here previously (sorry, can't find the reference offhand) that the timeline is fixed at 30fps.  Your solution is the one that you have already identified: render at 25fps.
Ah, OK. I guess it calculates the frames new if I set the export to 24fps, so the actual speed of animation won't change importing it into a 25fps setting in Davinci Resolve, Premiere or so... I will test :-) Thanks!
Tim
By Peter (RL) - 6 Years Ago
Hi... If you render say a 1 minute project @30fps or @25fps the resulting video will still be 1 minute long. :)
