By Siamax - 7 Years Ago
Hello Friends after my first time i bake IBl light in IClone 7 all my scene became dark ! After that all my older projects and new scene are dark , and i can't see any texture ! Srange think is the texture are exist but not shoing in viewport !
anyone know how could i ride of this big black shadows ?
thank you all
 Textures work in mini viewport but not showing in main viewport !!
By pka4916 - 7 Years Ago
I am pretty sure this is fixed in the upcoming 7.7.1 version 1 of the bugs I was having as well.
Thank you mate , but is there a way to fix now ? it is 3 days that i can't fix this problem !!! pka4916 (12/23/2019) I am pretty sure this is fixed in the upcoming 7.7.1 version 1 of the bugs I was having as well.
Don't think so. I am waiting for 7.7.1 to show up.
Was hoping today, otherwise tomorrow... with Christmas coming up, and was said before the holidays... so we'll see
By Kalle3 - 7 Years Ago
Hi siamax maybe this helps
sorry for my bad english but google translator dos not work greetings Kalle
Die Sound-Funktion ist auf 200 Zeichen begrenzt
Thank you Dear friend Appreciated your time , but it was not a solution I think Iclone created wrong Bake IBL light and stored to my default startup scene file and I did not know how to remove that ? Kalle3 (12/23/2019)
sorry for my bad english but google translator dos not work greetings Kalle | | | | | | | | |
All my new startup scene even old saved file have black shadow on every thing .. Please help me to find a solution..!
By 4u2ges - 7 Years Ago
This is a bad a** bug and again relates to the Preferences (numerous were already reported). As soon as I baked IBL I got the the same:
I could not restore default viewport mode with any settings inside iClone and ended up deleting Preferences key (CURRENT_USER) in registry and have iClone recreate it on the next run.
NOTE: Please do not follow this recommendation if you have never worked with computer registry. A mistake could be fatal to your system!! Better applying to RL support in this case!
Otherwise this is what needs to be deleted:
Oh... Yes .. thank you mate ... Really strange thing is here ..i have little experience about registry .. I will do that .. Does reinstall IClone can resolve the problem? Really appreciated your help , thank you 4u2ges (12/24/2019)
This is a bad a** bug and again relates to the Preferences (numerous were already reported). As soon as I baked IBL I got the the same:  I could not restore default viewport mode with any settings inside iClone and ended up deleting Preferences key (CURRENT_USER) in registry and have iClone recreate it on the next run. NOTE: Please do not follow this recommendation if you have never worked with computer registry. A mistake could be fatal to your system!! Better applying to RL support in this case!Otherwise this is what needs to be deleted:
Normally it does not, because that part of the registry is preserved. But the latest update might fix it (if RL fixed the problem, which I am not sure if they did, because nobody reported this particular problem). Try updating first. If that does not fix it, then delete mentioned Preference registry key and restart iClone. (again, make sure you are deleting from CURRENT_USER hive and NOT from LOCAL_MACHINE)
Fixed , Finally my beautiful colors back thank you friend ' I am sure I could not solve this problem without your help Appreciated
4u2ges (12/24/2019)
Thank you All friends My problem was solved with the help of a good friend 4u2ges message. appreciated all of your kindness
