By Ascensi - 7 Years Ago
Trial download is available. The following images are rendered in iClone set to 4k, the prop by default is set up for 4K for most users/machines. https://marketplace.reallusion.com/pbr-desert-frost-landscape-theme-pack
 When using ideal settings for iClone and IRAY I've made it possible to have the sand in all props and the sandstone in the Desert Cave prop sparkle but not only that, copying the AO to the color channel to produce snow, the snow also has glitter!
 I'll also be updating some assets with a sand sinkhole morph so it can swallow up your character or other things! Mountain/Forest props are next.
