Please Someone Help
https://forum.reallusion.com/Topic429488.aspx
Print Topic | Close Window
By clyde102 - 7 Years Ago
https://forum.reallusion.com/uploads/images/d51d01ce-9a23-4781-904b-78f6.jpg
I am using Character Creator3.x  and the lady is in the sitting position.This problem also occurs in I Clone 7.x.Obviously the dress does not drape properly. This is driving me crazy. How can I Fix?
By 3DChick - 7 Years Ago
Not sure if you're in Character Creator or iClone...If you're in iClone, I suspect you need to turn on physics for the dress. Right now, it's just following, but if it's one of the CC dresses it's set up to use physics to drape. If you're in Character Creator I'm not sure what to do, but you if you edit the title of this post to state what the problem is more specifically, I think more knowledgeable members will chime in. (If it won't let you edit the title, try reposting with a little more info).
Hope that helps!
