By cesar3dartist - 7 Years Ago
My characters are not showing up when I export to the Oculus Quest. They show up in preview mode inside UE4, but not once the project is built and I try the headset. Maybe there are guidelines to follow when using Character Creator for VR? I am using Standard material setting. Should I take anything else into consideration?
By kmitchell.12catblackstudios - 7 Years Ago
Do a windows publishing, then test to see if the character appears. You could either not be exporting the mesh on export. Or the way you are loading the character only works in PIE
By Zoediac - 5 Years Ago
I need help with the steps on how to upload my Iclone or Character Creator Avatars to the Occulus. Is there any form of guide? Can anyone explain where you upload them on the Occulus? Thanks.
