No Name Material Bug
https://forum.reallusion.com/Topic427411.aspx
Print Topic | Close Window
By e1_scheer - 7 Years Ago
Hi RL,
I've batch exported about 60 character models to Unity, but am running into the following
bug.Once I load up my character in Unity, a lot of the materials are missing and replaced
by "no name" materials :
Here's a snapshot of the hair materials in unity as an example of the problem :
On the CC3 side everything looks ok..  Here's the corresponding images in CC3 :
My hunch is that the problem lies with the fact of having consolidated
multiple materials.  It's as if the materials that were consolidated are
still present and assigned on a per face basis.
I can resolve the problem on the unity side by assigning the material
multiple times to the different material slots, but that's a pretty lame
workaround as I have to repeat the process countless times.
Any help or hints would be appreciated,
Thanks,
Iwan
So I've done a follow-up test where I've gone back to my original character before consolidating
the materials and then exported it to fbx and imported it into blender.  If I do this then the character
looks fine.
https://forum.reallusion.com/uploads/images/99d7593d-f217-4bc1-a0ea-04e8.png
However if I consolidate the hair materials for example and follow the same export and import
procedure the hair materials in blender are messed up.
https://forum.reallusion.com/uploads/images/d3fc588e-e736-4067-aac4-5a25.png
I'm amazed that nobody tested this feature all the way into export.  I'm really stuck now as going
back to previous versions means at least a week of extra work. 🤣
I'm now starting to wonder if consolidating materials exports at all.
Can anyone confirm that you can indeed cosolidate materials and then export the character to a 3rd party app?
By Scyra - 7 Years Ago
Somehow I missed this post. I have the exact same experience when consolidating materials. Manually assigning the No Name to the correct material in Unity does not entirely fix the problem—materials I left separate, such as metal pieces, are now sharing the same Smoothness slider as the rest of the outfit...not good.
Added to Feedback Tracker.
By e1_scheer - 6 Years Ago
I don't think the feedback tracker makes any difference.
I've posted several issues over the last year and none have made it into a release or a fix.
By Miranda (RL) - 6 Years Ago
Hi e1_scheer,
As far as I know, it's been assigned to the Dev Team to fix.
