By lundon - 5 Years Ago
I have created a category named "Bob" within Heads. Now I want to rename the category to "Joe". How do I do that? Now I want to get rid of the category "Joe". How do I do that?
Thanks
By 4u2ges - 5 Years Ago
It is kind of non intuitive. You have to actually Edit the morph itself and change the Slider path, which is = to custom category. If there is only one slider in custom category, then the category would be renamed. And if you clear the path, the custom category would be removed and slider moved into the root. If there is more than one slider, then renaming the path, would create a new category to which slider would be moved. To get rid of category, you'd need to rename a path for each slider it contains.
Wow, that IS non intuitive- but it works.
Thanks
