My Personal Explanation Of UV maps
https://forum.reallusion.com/Topic427011.aspx
Print Topic | Close Window
By Delerna - 7 Years Ago
MAJOR DIFFERENCE BETWEEN 3D MODELS AND 2D TEXTURES
I got asked for help on this topic so here goes. I hope I explain it well enough.
3D and 2D has their own particular meaning.
      3D has 3 dimensional. In other words there are 3 directions, Vertical, Horizontal and Axial
      2D has only 2 Dimensions, Vertical and Horizontal
This is the major point with texturing Models in any program like iClone
Models made in tools such as Blender are 3 Dimensional.........X,Y,Z
https://forum.reallusion.com/uploads/images/b8e8110f-0ba0-41b5-a2e3-2b10.png
But making textures in tools such as Paint.net are only 2 dimensional..........….X,Y
https://forum.reallusion.com/uploads/images/b0c9971d-9b3e-4370-bf9d-a6dc.png
So, in order to enable a 2D image to get added to a 3D model the person who makes the model must add a UV map to it. It is the UV map that enables a 2D image to get loaded onto the 3D model and it is the UV map that controls where the 2D texture parts get added onto the 3D model. The primary point is, the UV map can only be created by the person who made the model. People using the model in programs like iClone can not change the UV map. They can only use the UV map made by the person who made the model to see where they need to put their images in their 2D texture so things show up on the 3D model in the right place.
HOW 3D MODELLERS CREATE THE UV MAP FOR THEIR MODEL
Once the modeller makes their model they must create a UV map so that 2D images can be used to texture the model.
Here is an explanation for how its done in Blender. All 3D modelling tools enable creation of UV maps for 3D models but the way its done can be different to how its done in Blender.
But its the completed UV map that ends up the same. And again, the key point is that it is totally up to the person who made the model as to how the UV map gets created.
No one else can change them in tools such as iClone. So how well the UV map enables 2D images to look on the model totally depends on the capability of the modeler.
Any UV map enables 2D textures to show up on the 3D model. But how easy it is to position the textures on the model depends totally on how well the modeller creates the UV map.
By the way, I didn't try to make this UV map well, I did it like this in order to try and show how difficult texturing the model can get if the UV map isn't done well.
You can still texture the model properly but it takes a lot of work positioning the 2D textures so they show up in the right place on the model.
First up, these 3 images show one way of adding the models parts to the UV map. Exactly how its done depends on the model type and also making the UV map to make texturing the model as easy as possible.
One thing I see is its really hard to make it 100% perfect. Just got to get it as good as possible
https://forum.reallusion.com/uploads/images/b5939ab8-dfaf-402f-bb89-277d.png
https://forum.reallusion.com/uploads/images/a6a5a17f-4eb6-4d3e-ad86-ae96.png
https://forum.reallusion.com/uploads/images/4d343efb-d006-420e-9b4c-ba1d.png
OK, once all the models parts have been added the UV map needs to have the parts scaled and positioned in the best way possible to make it so the 2D image works as well and as easy as possible.
These 2 images give a demo of that. The primary thing for people using it is that where I put the model parts I created shows where you need to put your 2D texture parts in the image so they show up on the correct place on the model
This image shows where the models items got added to the UV map. Texturing works with this although some parts of the model are over each other so the some parts of the texture that gets added to the model will appear in several places. That is fine for some models and not fine for others. It all depends on the model getting made and the types of images that might get loaded onto it. That's what makes deciding what the best way to create the UV map is and if someone starts doing texturing different to what the modeller thought would get used on the model then it works but it might make more work needed for the person using the model to create the texture they want to use.
https://forum.reallusion.com/uploads/images/935edc61-67f4-4f72-a869-1883.png
Anyway I decided here that I want no part of the image to show up in more than one place on the model so I scaled them down and then positioned them apart from each other.
It also matters which way I rotate them so the images added to the model not only show up in the right place but are also in the correct rotation. Mind you, certain parts of the image you create can also be rotated separately so they show up on the model in the right place and in the right direction. Another point I will make here is that the whole models parts are connected to each other but I set them in the UV map so there are 3 parts and they are not connected to each other. This can make it difficult to make a texture where there are lines that need to be aligned with each other. It can still be done but it means the lines in the images might need to get moved around so they end up in positions so they line up with each other in the model. This is a thing with UV mapping. Keeping everything connected together in the UV map so things line up properly more easily can make other problems. For example the edges now line up but the centers aren't straight anymore. So now you don't need to reposition things so they line up easily but getting lines to stay straight might mean the lines in the image need to get curved so they look straight in the model.
Hope that helps you to see that getting UV maps setup to cover everything to be 100% easily done is not possible. I for one try to make them as good as possible for what textures I think will be used on it.
https://forum.reallusion.com/uploads/images/af345bd3-7cc6-4da3-b7be-0418.png
CONVERT THE MODEL FOR USE IN iCLONE
Just adding this to complete the method. Its not really about UV maps
Anyway, I generally save it from Blender as an fbx file
https://forum.reallusion.com/uploads/images/1de46e08-4ebe-4140-83b0-1001.png
Then load it into iclone 3Dexchange and make any adjustments I need.
Then I export it as a model for use in iClone
https://forum.reallusion.com/uploads/images/695350ea-f8d7-414e-8c3e-f665.png
TEXTURING THE MODEL
Ok, here is the image I am loading onto the model
https://forum.reallusion.com/uploads/images/4fb731b1-4da9-4bdf-99ad-0dcb.png
And here is the result....ooooo yuk doesn't look great. How can I change the image so things show up correct?
OK, more posts coming to show how I do it.....how you do it? That's up to you, you will find a way that suits how you work.
https://forum.reallusion.com/uploads/images/e7c10c2d-0f64-4053-afa3-6ea9.png
FINDING OUT WHICH PARTS OF THE UV MAP SHOWS UP ON WHICH PARTS OF THE MODEL
First I send a models base color to my 2D editor, I use paint.net mostly.
Then I send the models UV map to my 2D editor.
This image shows how to do that
https://forum.reallusion.com/uploads/images/4991c635-8568-47b0-a4c5-d123.png
And here is the result in paint.net
https://forum.reallusion.com/uploads/images/1db8efe8-113b-4f79-8dc0-b4ee.png
In paint.net I go to the UV map and remove the black colors from it. Then I add another layer under it so I can draw on it.
My first drawing will be to help me understand which parts of the UV map show up on which parts of the 3D model.
Actually, I only do that if I am not sure which ones show up where on the model.
Here is a demo of doing that
https://forum.reallusion.com/uploads/images/4b8b2367-214f-4b49-b3a0-c93b.png
And here is the result of it in the models in iClone
https://forum.reallusion.com/uploads/images/bac3a923-8118-433e-b434-d23d.png
OK, so now I know which UV parts show up where on the 3D Model. In some cases I might even use more different colors on more of the parts so I know even more which UV parts show up on which parts of the model
Here are 2 images demonstrating what I mean
https://forum.reallusion.com/uploads/images/65e05429-4440-40bb-89dd-70d4.png
https://forum.reallusion.com/uploads/images/a4dd22cf-6f61-4ea5-ba20-466b.png
Anyway, now I have a good idea where to start putting the actual images I want to start adding to the model and I can also see what size I need to make them as well as where they need to be rotated so they are in the right direction.
I will be demonstrating that next
START PROPPER TEXTURING
OK, here are a couple of photos I will start to use to texture the model. I will coppy the bits I want and past, scale and rotate them to fit the UVMap parts.
I will also delete the parts that aren't needed. What I show here is pretty rough because I am not spending that much time to make it perfect. Rather I am just demonstrating some of the methods I use.
Need to spend enough time to get these images to look more correct
https://forum.reallusion.com/uploads/images/1b76f38d-1d0d-458e-810c-1b32.jpg
https://forum.reallusion.com/uploads/images/661ec99c-f56b-46e5-86ca-48e1.jpg
Now, here is where I added the parts from the photo's that I wanted to use. Then I combined the needed layers into a single layer, coped it and then pasted it into the base color image and then save it so it updates iClones models
https://forum.reallusion.com/uploads/images/b880aaff-730a-4128-a158-25f8.png
And here is the result. I am stopping here. If anyone has questions I will try and add answers here in the posts I haven't added anything to yet.
By the way, I just dragged the base color into the bump map to make it look better. Really should at least convert it to black and white or even better, as a proper bump map... but still, it looks OK I think.
It does need more work to make it better and especially, me as the model maker should make the UV map better so its easier to get the images look better. But this is just a quick demo and not a proper model so this will do for this.
https://forum.reallusion.com/uploads/images/2822cd47-f9be-468b-b209-b282.png
SETTING  UP iCLONES TEXTURE PROGRAM
https://forum.reallusion.com/uploads/images/a99c18ea-4213-4488-b9d6-e133.png
keeping this to answer questions if needed
OK, I have finished demonstrating this.
If any questions come I will try and attempt to answer
By Rockoloco666 - 7 Years Ago
Thanks for making this, i wished for something like this 4 years ago, trying to figure out uv maps by yourself is a major pain and the information on the internet is rarely as simple as what you posted here. UV maps were so frustrating and infuriating for me. This will surely help a lot of new comers and should be pinned in the forums.
I will make a small contribution to this post:
An awesome and kind of easy to use software for uv mapping is 3d coat, the tools are simple and easy to use. The only downside is the lack of newbie level tutorials and some tooltips and windows are in broken english.
For creating materials (diffuse, normal, roughness, metallic, height maps) from a simple bitmap there are 3 options that are quite nice:
Substance super tools bitmap2material available in the content store, and works inside iclone. Alternatively there is the bitmap2material form allegorythmic, has even more options to fine tune an image and the best feature is the make it tile option, this is good for making seamless textures. Downside is allegorythmic was bought by adobe, i currently don't know what the licensing terms are and if a perpetual license still exist.
lastly there is a freeware called awesome bump which is quite powerful and has many fine tuning options, and best of all is free. the downside is that UI is not exactly the best around but it isn't the worst either, but once you get the hang of it it is very easy to use
Again, thanks Delerma for making this topic and for the time invested in doing it
By wendyluvscatz - 7 Years Ago
and the simplest illustration of what a UV is ....
https://i.redd.it/g84k861qdd301.jpg
By vidi - 7 Years Ago
lol wendy I had thought of the same :D
Raxel 67
Thank you, yes I wish that when I had started learning these things that I had found tutorials that explains things as fully as possible and keep the words as simple as possible so more people can understand what is being shown.
I don't think of myself as a expert teacher, I just try and help people as best as I can and I can only show things as I understand them. Hope it helps some people.
Wendyluvscats and Vidi
Yes you are right, that is a really simple illustration of what a UV map is and if some people find that is enough then great, you have showed them well enough.
But I don't see that it really explains how to use them in something like iClone and I say that because over time I have helped a couple of people to get started with it. Also it took me time to figure things out when I started too.
As I stated at the start of this post, I had another person ask me for help with UV and texturing models and this time I decided to post it here because I thought that maybe it might help some other people too.
That's why I wrote all those posts that show why and how UV map's get made, who actually adds them to the model. And finally, I tried to show 1 way people can figure out how to get their textures to show up on the correct place on the model they are trying to texture in iClone.
I think knowing these things might help some new users of them to understand why they are made the way they are made and how they can go about finding out which parts of the UV map show up on which parts of the model so they can get their textures in the right places.
my light humor was not meant to detract from your posts:ermm:
Sorry Wendy, I was just trying to state why I did what I did so other people reading these would know.
I am getting old in my head most of all and find some short things written hard to understand what is meant
I see it also a sweet additional to the value Information in this tread
OK, silly me...….. I especially apologize to you Vidi.
It was what you wrote that got me thinking I was being laughed at for writing so much.
If you had added a little something like this new post in the other one I would have understood what you were saying.
All of what has happened here from what you wrote and how I felt about it is definitely not that big a deal, however I will add this.
In real life it is the sound of the voices of the person making a statement that helps us understand what they are saying.
But in texture only ...…. there is no voice sounds to help all people understand.
That's a big reason why I write so much text when I write text, I try to make it as obvious as possible what I am saying especially If I am being funny.
I have shared that image on many sites and threads on the subject of UV unwrapping
as thought it was cute and illustrated the concept well.
I must admit I have never gotten a reaction like this before :w00t:
I am Australian though, perhaps we think a bit differently :crying:
LOL, I am Australian too......hmmmmm I must be a crazy ausie
Although, I didn't think anything bad of the image you posted
pressed twice again
By animagic - 7 Years Ago
I think the image of the wrapper is complementary. It shows the idea.
To create a wrapper like that is another story and requires a more extensive explanation.
If someone think a UV Map is a complicated thing , the sweet analogy shows also it isn't.
By rollasoc - 7 Years Ago
Thank you for the tutorial, that has cleared up a lot of confusion for me as to how they are created.  It never made sense to me before.
I'd look at one UV map and it seems to make sense, then another for a similar object and it would be totally different.  It confused me.
The chocolate wrapper example is both complementary and an eye opener, in showing me a real world example in actual 3D (as opposed to virtual 3D) and gives me an excuse to buy some chocolate.
The tutorial thus explains how to create the chocolate wrapper.
By rosuckmedia - 7 Years Ago
@Dilerna
Very interesting topic, I'm just trying my UV Unwrapping
with 3D Coat. Greeting rosuckmedia:)
