By JimmyB7 - 7 Years Ago
I found the ones where the model is looking straight into the camera with no teeth showing work reasonably well in CrazyTalk 8.13. Regardless, they are free.
By charly Rama - 7 Years Ago
Thank you , very interesting
By animagic - 7 Years Ago
Thanks, JimmyB7. A great resource.
By Peter (RL) - 7 Years Ago
JimmyB7 (9/23/2019)
Free but non-commercial only at present. Still very impressive as they claim the 100,000 faces were AI generated from just 69 different models.
Here is one created in CT8 and then applied in CC.
Original:
CC native render:
Would be good for a variety of background characters.
By Kelleytoons - 7 Years Ago
After some modifications, I ask to myself if there's a way to prove it's this or this image source for this avatar. I look at all the avatars we made, they are all good but hard to say they come from the same picture if we didn't see the origin
By justaviking - 7 Years Ago
Good thread. A very interesting resource, and some fascinating results. It's interesting how the "same face" can be different for every person.
Comparing Kelleytoon's results to Charly's render... How much of the difference is due to lighting? Are they ifferent faces to begin with? Or is there more afoot?
@Charly - Did you render with Iray? I get the feeling there is some sub-surface scattering happening, I notice a particular different in the nostrils, where KT's are much darker and more shadowy, whereas Charly's has some pink and isn't as dark. If you used Iray, could you also do a standard CC3 render with Reallusion's PBR renderer?
Oh no, I gave up with Iray, it's nativ render. I 've got inspiration with unreal lighting, nativ render is plenty of possibilities and i canot even imagine what it will be with future realistic shaders...
charly Rama (9/25/2019) Oh no, I gave up with Iray, it's nativ render. Oh, well that's great news. I thought your render had a somewhat softer look. All are good, but of the three I'd put yours on top.
Just default CC3 lighting? I'm trying to figure out why yours is so much better (I just used what CC3 comes with).
No, I just added two spot light and played with light colour
Another exemple :
from this
I made this
But you're using Crazytalk for the heads, right?
By Hewa' s Art - 7 Years Ago
Thanks, JimmyB7 for sharing this. A great resource.
Kelleytoons (9/25/2019) But you're using Crazytalk for the heads, right?
I always use facegen, I find there're more possibilities and above all choosing bake textures for max in 4K, I think that makes the difference. I made this from a picture of DEFOE, it's not iray
I usually use FcaeGen as well, but I don't have access to it at the moment. Still, even CT8 can give decent results with a good photo and a bit of effort.
By tkamal81 - 6 Years Ago
thanks a lot
