Iclone for Archviz?? repost.
https://forum.reallusion.com/Topic422940.aspx
Print Topic | Close Window
By wildstar - 7 Years Ago
After last iclone changes i start make some tests . what changes? you can ask..
1 - the great performance bump , iclone is real fast now and is dealing with high poly count as its never do.
2 - IES light system
so i start a project animation with 2 not optimized cars for realtime ( each car with 1 milion polys ) 2 avatars , a custom terrain i made in mudbox, and more than 900 speed trees 20 cameras already ( will be more ) . and iclone is dealing with it at 40 fps without VXG and 20 fps with VXGI , for me its amazing speed bump. now in iclone you can import fbx using drag and drop on iclone viewport and 3dxchange get performance bumps updates too.
so i realized one thing. 3dxchange import a car with 1 milion polys at light speed and convert it for iclone fast too.
but with a archvizscene wit 1 milion polys but a lot more materials. something like 50 materials + 3dxchange got 30 minutes( the same scene get instant pop up on toolbag 3 and unity  ) . and this dont change when i reduce polycount, i believe its cause the big material quantity.
so.. why use iclone for archviz???
well... after studying all this realtime engines i undestand the power of iclone. and if you compare it against twinmotion for example iclone only lose against reflection probes for realtime reflections. ( you can get a aproach with ibl baking but is not enough )
iclone have a better VXGI system than twinmotion. twinmotion only get global ilumination for sunligh not for artificial lights
iclone can get global ilumination from direct light ( sunlight ) spot lights now with the plus to use IE lights system the emissive props can simulate area lights . iclone have better AO than twinmotion if you use iclone VXGI shadows + HBAO+ in correct way you can pass twinmotion results. more fast rendering for 360 animations. i hope reallusion undestand iclone is more close to fight against twinmotion and lumion very soon on they market.
i working on my Virtual reality show reel using Unity and i get one of the scenes and start tunning on iclone and got this. :O.
https://forum.reallusion.com/uploads/images/1ec85799-634f-4bb4-9dd6-d126.jpg
lets make a exercise????
Unity progressive https://forum.reallusion.com/uploads/images/5181c5b9-84a3-4f72-895a-e08a.jpg
Unity Realtime ( similar to iclone vxgi )
https://forum.reallusion.com/uploads/images/a59f92da-9d3f-4409-b95e-e37f.jpg
iclone vxgi
https://forum.reallusion.com/uploads/images/1a4c93a9-2a84-42df-b34c-6aca.jpg is not enough say " image x is more realistic, lets talk about what make one better than other "
By 2IDs media:design - 7 Years Ago
Hey Wildstar,
really a very good work....one question...
would it be possible that you share this scene / iproject with all of us to optimize it
like a competition between all Icloners?
So we can share our experiences about iclone, unreal and our workflows to
get the maximum creativity?
Thumbs up :-)
By AutoDidact - 7 Years Ago
First the Iclone is obviously missing the reflections on the parque floors.
 Assuming you are using identical light sources,Both the unity RT and the iclone render have light leaking through the right side wall into the stairwell.
The unity progressive does not.
.The Unity progressive has way more accurate shadows being cast by the dining room table and chairs from the lamplight
.the Iclone render has none except on the floor and the lamplight is doing nothing for the general illumination
.Overall the Iclone render would be useful for an animated film however it does not even begin to approach the level of realism& detail expected in the Architectural visualization industry.
2IDs media:design (9/19/2019)
Hey Wildstar,
Thumbs up :-)
i try do this yesterday the file is 240 megs. o will try it again today yes will be fine , lets ppl dont only talk about but showcase your point of view
AutoDidact (9/19/2019)
you are tottaly right my friend. i agree with you. but iclone can give better results than twinmotion with we have today (less reflections)  the problem is how 3dxchange deal with arquitectural models, is not optimized for that. BIM or FBX if get many materials can get hours to 3dxchange to convert .
By TonyDPrime - 7 Years Ago
wildstar (9/19/2019)
Hey Wildstar,
Thumbs up :-)
Wildstar - I have mixed feelings on this.
PRO - you will learn from others new things that you had never considered before, and then from there you can make it part of your own approach.
This will work so long as those making optimizations have full guaranteed ability to provide you with specific technical measurable measures they are utilizing.
CON - This is your work.  For me, I would show you MY work and ask for your input on what I can do better.  But I would NOT ask you for your scene.  I would send you MY scene and ask for your input on MY scene.  I would pay you for that input as I value the exchange.
And look - there is always the 'Loft Scene', that everyone has access to and can try their best at.  Let others show you their work with that scene, which again, everyone has access to.  A contest doesn't need to be run with your scene.  As a user group we already have scenes ready for contest.
I always have respect for your work and your insights.  As I myself have been approached and been now more involved in professional interactions, I find that serious interest is handled in a professional manner.
But, the forum is a free exchange of ideas always, so this is just my specific opinion on this topic and doesn't have to be yours or anyone else's.
eh the file is not upload... i will send it to rampa..
this was not my idea other ppl talk the same thing cause using a same scene will be more easy to point visual resources. btw. i cant upload the file on forum something happened.
the last image from this test a version from toolbag3
https://forum.reallusion.com/uploads/images/be6e7b0c-f954-40f1-8e6f-8cd6.png
Rampa?....
Wait - Rampa...Shared scene...
LOL!  That Deja-Vu'd me!
https://forum.reallusion.com/FindPost333441.aspx
my toughs about this tests is one thing i undestand already from 2 or 3 months back .
progressive lightmap from unity or unreal lightmass are the best thing you can see on realtime engine world ( puting at side RTX )
BUT for story telling you dont need the lightmapping precision you need powerfullshaders for the characters . VXGI brigh in dinamic characters is better than lightprobes cause it dont have the same precision from the lightmapping on statics objects and deliver less precision than vxgi. the same happen with dinamic lights particles vfx... the fact reallusion uses HBAO+ in layer with vxgi shadows. give the user the power to get amazing results in AO side better than toolbag 3 for example. the toolbag impress with your powerfull material system and stupidy powerfull shadow system with monster soft shadows. if you get this from toolbag for iclone. will make iclone a monster realtime engine tool.at the moment my main tool for render is unity cause i have the best from both sides realtime and no realtime, plus a lot of visual resources caming from scripts make for third party users. ( this is one of the reasons me and almost no one is using HDRP cause is just incompatible ) btw. i go back from my working animations i working for my site ... cheers! :)
By Rampa - 7 Years Ago
The loft is great, but this scene is unique in that it has the stair wall to deal with.
I think we all learn more by working on something common, as the variables are often so different for different scenes.
My suggestions would be to start with the existing materials and lighting, and then improve them as much as possible.
So adjust the light parameters, but maybe try and keep the same basic time of day for the outside light creating the shadows.
Use the existing material diffuse, but modify the material s however you wish, including adding additional textures for other channels. Basically, make it pretty! :)
Do it for fun.
Rampa (9/19/2019)
Do it for fun.
Rampa, did you ever put up a scene to share with the community yet?
Give us the Dropbox link, let us give it a whirl!
the scene is with rampa already , the unique thing i ask is just to use for internal only on forum thx.
I'll have it posted shortly. Was out on a bike ride! ;)
Gave this its own thread here:
https://forum.reallusion.com/423044/Architecture-Visualization-Render-Contest
You can download the scene from the new thread.
