Cartoon Animator 4 - Character to PSD Editor Not Working!
https://forum.reallusion.com/Topic420067.aspx
Print Topic | Close Window
By greatdahn - 7 Years Ago
Hi, I'm using Cartoon Animator 4 (4.02.627) Pipeline on a Mac and the export character to PSD editor is not functioning at all...
I have selected my version of Adobe Photoshop in the preferences. It has worked previously but has stopped for some unknown reason...
Anyone having this issue?
By ichem15 - 6 Years Ago
hi, i have the same problem. Do you find the solution ?
By Peter (RL) - 6 Years Ago
ichem15 (8/17/2020)
Are you using Windows or Mac version?
It's also worth opening your selected image editor first before trying to use PSD workflow options.
One other thing to check is that you have your chosen image editor correctly setup in Preferences (see below). If you don't have either Photoshop, Affinity Photo/Designer, Clip Studio Paint or Krita, try the Photopea option to see if that allows you use the PSD workflow options.
https://manual.reallusion.com/Cartoon_Animator_4/ENU/Pipeline/Content/Resources/4.0/10_Preference/Texture_Section.htm
