Hi...
There may be an issue where the incorrect recording device is setup as default. You can check which device is setup as the default by going to your Windows Control Panel > Hardware & Sound > Manage Audio Devices.
Then make sure the microphone you are using is selected as the default. If this doesn't help, try using a different recording device (if possible) and see if you have the same problem with that.
