Changing ICLONE4 Language
https://forum.reallusion.com/Topic418605.aspx
Print Topic | Close Window
By thegreaticeman - 7 Years Ago
Hi all.... I know this forum is an old one, seen as IClone has moved on a LOT since v4, but I hope someone can help.
To cut a very long story short.... I installed IClone 4 BUT its in Dutch.
(It is a legal install via reallusions)
Anyway... I need it to be in English so I was wondering if there is a way to change the language.
In most software you can go to edit....preferences...then select a language.  Or sometimes you have to change an INI file directly.
So... how can I change the language with IClone4 to English.?
Thanks.
By animagic - 7 Years Ago
I'm only aware of a German version. Is that what you have? If so, that is a different executable altogether as far as I know.
LOL... yes your right... It is German... dont know why I said otherwise!?!?!
So then... can the language be changed?
By toystorylab - 7 Years Ago
NO, two different versions.
toystorylab (8/1/2019)
Ah ok.
Well then it looks lilke I will have to contact Reallusion over it then, as it was a give-away and the code I got from them SHOULD have been for English, so it looks like the problem was on their end anyway so Im sure they can sort this out for me with a simple link to the english version.
Thanks for the help all.
Cheers!
