By boxels - 7 Years Ago
I made this using the AI template. Exported to PSD, imported to CTA4. Why do the arms not stay where they should at the shoulder joints? What is happening here.
Issue can be seen at 34 seconds on the video.
By vepop - 7 Years Ago
Click the bone and see if there is any sprite in it.
Thanks for your reply. I am using one single arm for this character. No separate forearm or hand. Did I set something up wrong to make CTA 4 move the shouder out of joint like that?
If you can share the file ... then I will be able to check the error.
Files
Bring the RArm bone slightly lower.
Wow! Nailed it. Thank you. I guess you gotta make the mistake once to figure out the solution. So the bone has to be right on the sprite?!
Thank you! Saved me so much headache. Tried to fix this in any other way possible. Appreciated!
