By charles_samuel2000 - 7 Years Ago
I bought Cartoon Character Designer : Toon Figures. Had a difficult time loading it. I got the " toon hair" loaded. But i haven't been able to load the "toon figures at all, or haven't I? All I have is (look at image below) is this..... Cartoon Base 3DXFACeANIMPoRFILE File... But i don't know where to put ti so I can open the neutral base figure and the other figures of "toon figures". I've tried to open it in 3DXchange, Iclone7, and Character Creator 3, to no avail.. Someone please HELP!!!
Thanks!
By Kelleytoons - 7 Years Ago
When you open CC3 you ought to see them there as both characters and morphs.
Thanks for your reply. But no. I don't have them in CC3. What do I need to do to get the toon figure folder there? Also when I download the files I boght for the toon figures all I got was a zip folder that said "Toon_Figures_FaceAnima_Profile" which opened up to reveal the previous image of "Cartoon Base". If this is all there is to it, where can I place the file and how. in CC3?
Go to your account here and download the NLD file, which will install them correctly (you just run it).
NLD File? Do you mean the reallusion content downloader?r
When I click on the toon figures, cartoon bas,e it open up iclone 7. but I cant find find the files there.
Kelleytoons (7/15/2019) Go to your account here and download the NLD file, which will install them correctly (you just run it).
Right, you download the content in the NLD, and run it and it will install your content in the right directories. You cannot do this manually.
By Peter (RL) - 7 Years Ago
charles_samuel2000 (7/15/2019)
The file you need is called Install.RLD (not NLD). So go to your Reallusion Account > Order History page and click the Download link and then click the Install.RLD download link (see below).
Thanks, Pete. With all the drugs I'm on it's amazing I got that close.
I used the RLD (various time), i get the toon figures download and all I get is the "cartoon base" If i click on it, iclone 7 opens up, but there's nothing there. Isn't the toon figures file supposed to be in Character Creator 3?
OK Guys, this dunderhead FINALLY figured it out. I was to download the toon figures first, then the NLD, then press ONLY the NLD which will download everything into its place. Thanks for your patience with me.
Cartoon Character Designer : Toon Figures-- some basic problems...1. The jewelries will not stay attach to the bone areas. What am I doing wrong? 2. Is there a way I can cut a piece off of the hair? 3. The hair change color from CC3 (blonde) when I upload it to iclone 7 (white), How can I prevent this? 4. Why is the appearance editor grayed out, is there another way to activate it in CC3? If you have suggested, Thanks!
By juliein3d - 7 Years Ago
I have the same issue, in fact I get the hair, teeth and eyes that are Toon but no toon body or face, so no avatars. I did get the zip with them AND I did run the installer several times in fact. Nothing but hair, teeth and eyes for Toon. How do I get the actual avatars into CC3? This was pricy, the Cartoon Character Designers Bundle. Cost me $200 smackers so need to get them. See below this is after running Install.RLD
They have cartoon bases under Skin but they don't come as a figure, is there such a thing with this pack, defaults that you start with that look like the characters in the ad? I'm trying to find the how to on this to create characters like the ones we see in this marketing. Seems odd not to have character default presets that show up under Avatars that you can drag like the ones you get from Hivewire or from Essential Morphs.
juliein3d (12/14/2019) They have cartoon bases under Skin but they don't come as a figure, is there such a thing with this pack, defaults that you start with that look like the characters in the ad? I'm trying to find the how to on this to create characters like the ones we see in this marketing. Seems odd not to have character default presets that show up under Avatars that you can drag like the ones you get from Hivewire or from Essential Morphs.
Hi... The Toon Figures can be found under Project > Character (Avatar) > Toon Figures (see below).
