By firefighter1531 - 7 Years Ago
HERE IS A SCREENSHOT OF INSTALL HAS ANYONE ELSE HAD TH IS PROBLEM.
I Have found the fix for this if you have the same trouble type in iclonepy -m pip install pillow
also if anyone has an answer to why i got the warning or a fix for the f2py install path it would be greatly appreciated
By The-any-Key - 7 Years Ago
As the warning state. You don't have f2py in the PATH. The system paths. But as this is just a warning and if everything works you can just ignore it.
By animagic - 7 Years Ago
You should have both D:\Program Files\Reallusion\iClone 7\Bin64 and D:\Program Files\Reallusion\iClone 7\Bin64\Scripts on your path, and you should ave no errors.
